xt350 runs like crap
try adjusting the mixture screw, note where it is first so you can return to that point. I would guess it's clockwise to lean and anti clock to richen on this bike
Hmm did you spray through the little passageways in the carb as well as cleaning the jet?...really you should have done while it was off,
DT 175 MX chain adjustment guide
Try this Alan Put the bike in 1st gear and push it backwards to tension the top run of chain, hold the tensioner down off the chain, and adjust for 50mm slack in chain, both wheels on the ground mind. Actually the books says 40-50mm of slack
Bike Cutting Out And Not Restarting
check theres a strong flow of fuel to the carb grouch
I never use the notifications myself. Dont you get email notification? I expected thats how it would work
fek fek fek fek
yeah I know it was but if I had a penny for every time you have related 'crank seal' to 'hard to start'... I'd have at least 10p by now mines on order BTW
fek fek fek fek
ohhh hard to start mag side seal
Dyno tuning my dt
If it's got a #240 jet in there just stick a #250 in and away you go thats what I did and I had a bigger snorkel and boyessens, the bike ran well
fek fek fek fek
Bugger its been so reliable too! wonder what brought that on?
Dyno tuning my dt
If its running perfect as it is I'm baffled as to why you want to throw money away on a dyno...Its got a filter aleady and buying another will be wasting more money IMO If you want to play safe just put the next size jet in and enjoy it for what it is they are great little bikes. The black oily stuff is normal on these it's just unburned two stroke oil, mine used to do it too
hi there anotherone from the northeast
Greetings Lee and , bet that mini is worth a few bob now then eh?
Dyno tuning my dt
yep it'll cost you that will quill exhausts have a dyno if you want to contact them with prices...keep us informed though
dt400e (mx)
http://www.cmsnl.com/products/case-chain_4e7223110033/ http://www.ytcn.nl/archief/Archief/Yamaha%20Parts%20Manuals%20ALL%201950-1996/DT/DT250E_400E.PDF
Testing my new Drift HD camera in low light...
Thats another downside to mine too...the mic is too sensitive
The difficulty may well be removing the float bowl screws, sometimes they will need a sharp rap with a lightweight hammer, and always use the correct philips driver.
I've got a drift X170 and the auto exposure is rubbish, try record something in bright sunny conditions and you have nothing but blackness! is it me? whats this like in bright sunshine then...i'm sure mines ok on dull days?
I need Yamaha dt 125 re rear clear indicators
ebay of course
RT3 kick-back
Yeah show us another one of your pullovers haha.... please
tw 125
Wel it does sound like it could be the choke then armfaw...I'm not familiar with it though so sorry I cant help further...best get the carb checked out
DT 125r cylinder/head swap over
The 125 has crancase induction, It's a more modern way
tw 125
Perhaps but not necessarily How exactly do you 'Tip petrol into the carb' ?
Hello...from a new member
Greetings RubyStella and
XV 125 Virago - Vacuum issue
cant see the picture kelum
RT3 kick-back
I doubt it John it will almost definitely be a flywheel magneto jobbie, so it's my guess this thing carries it's own batteries
Testing for electrostatic discharge
yup I did once. messing about with an old microwave, what a thrill!
