Airhead
  1. looks and sounds fab mate I saw the vid
  2. dont know what you mean by that, some of them have a reduced diameter between the bearing surfaces at the ends what is the exact length of the original one?
  3. Nice alex it was a bit of a mother 24s in eh
  4. is the lever loose on the splined shaft or is there another issue here?
  5. thats nice alex, a great workshop too, top drawer. That silencer looks great is it a G.P.R?
  6. of corse you see em on ebay fairly regularly...how come you want one BTW ?
  7. hi kostas three things 1 what's an astragalus ? 2 has the bike got a kickstart? 3 what about the charge (source) coil specification and measurement?
  8. youve only had it for four months...take it to be looked at if it's under warranty Oscar
  9. get it tightened quickly Oscar or you'll bugger the splines!
  10. Airhead replied to drewpy's topic in Projects
    say hello to Tony from me
  11. check out the breathers first...the water has to have somewhere to go
  12. yeah a daily commute of only 4.5 might me the cause try riding straight past work and head out into the countryside
  13. maybe a call here? http://shop.bruun-larsen.dk/en/mc-spare-parts-25/yamaha-reservedele-26/frame-parts-32/shaft-pivot-dt125-tdr125-1367.html
  14. I doubt it...why would it be better?
  15. must have took an awful lot of condensation to do that, check all your breathers are clear and clean
  16. I can see this being a great job, tell us about the vinyl wrapping as you progress... I've never seen it done and would like to see how
  17. no youre not maga testing them, mega tests are for insulation breakdown and charge 500v into the components...no need for that you will use an ordinary multimeter and take resistance readings having switched your dial to the appropriate range for the expected reading...unless your meter is a modern auto ranging jobbie, you'll have plenty of time to pinpoint the fault if the engine needs to cool at this stage we just need to know if the spark disappears when it's quit
  18. I thought as much, It makes the whole project so much more difficult due to sellers unwillingness to export items and also so much more expensive! so you really need a good bike to start with that doesnt need many replacement parts...I see yours does look quite good from the photos
  19. well you have at least 3 coils to consider 1: The HT coil 2: The source coil in the magneto 3: The pulser coil in the magneto Check your manual and see what resistances are quoted for these coils and note them down along with the associated wire colours Chapter 4 Ignition system will give info on how to check these coils
  20. how is it getting parts from ebay in Norway? are there parts within Norway or are you having to buy from other countries?
  21. does it only happen when the engine is hot then...next time whip out the sparkplug and check if it's sparking, If not it may be a coil going open circuit under high temperature, it will be easy to check with a multimeter
  22. Airhead replied to paul-666's topic in The Bar
    I'm more than happy with my bandit 600
  23. Greetings crossplane, i'm same as blackhat It's out of my league too is that i'm only just getting to grips with YDIS
