Airhead
  1. from what Ive found there may be a bolt in the bottom of the healight rim, take out the bolt and prise out the rim from the bottom and it will drop down from a locating peg at the top centre...it may be different but see how you go
  2. your main beam should be just as bright as your dipped beam, you may have a dirty HI/Lo switch contact, or dirty / corroded main beam supply connections anywhere right up to the bulb holder, Clearly it's not an earth problem because dipped works fine
  3. Airhead replied to Evan84's topic in Yamaha Workshop
    might be worth checking out a dt125/175 tank maybe?
  4. Get youself some de-ionised water from a car parts shop and keep on top of the levels in your cells I wish you'd use the terms Dipped and Main, your comments are a little confusing! Perhaps your headlamp is pointing to far skyward?, try loosening the bolts and adjusting the tilt down a little I'd still like to know if these devices are regulators because they have screw fixing, metal body and cooling fins !
  5. well like has been said, you'll cook a 6v battery in no time (keep an eye on the cell fluid levels) Check if your bike has a regulator and that it looks ok...hasnt become disconnected etc Time and again we seem to come back to charging issues on theses old single cylinder yamahas, I see some of them make no reference at all to a VOLTAGE REGULATOR, but they have a VOLTAGE RECTIFIER. Then I see that the RECTIFIER has a sturdy bolt fixing and 'COOLING FINS' !!!? Why? why does it have cooling fins if it's only a rectifier? Because maybe, just maybe it is more than just a rectifier...maybe it's a regulator/rectifier (reg/rec)...regulators need cooling fins. I wish someone would get to the bottom of this issue! http://www.ebay.co.uk/itm/Yamaha-DT125LC-RSX100-Rectifier-/380765719622?ViewItem=&item=380765719622&nma=true&si=CzRQzZZ1CJrmFwwiRMDLxFKhnac%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557#ht_22wt_958 Its about time you had that haynes book fella
  6. +1, Take the battery voltage issue further before fitting a new bulb
  7. Oohh yeah, its a noobs intro spot !
  8. It's a good idea to disconnect one side of the battery and give it a charge once every 4 weeks or so, no need to leave it permanenty on charge.
  9. Merry Christmas to all our readers...and writers
  10. Greetings birthday boy
  11. Christmas greetings lallasro
  12. Greetings Danie
  13. 'if' not when Grouch
  14. stop talking about strippers it's not the way forward !
  15. Got my prize today too Lee, thanks very much
  16. just make sure the lever doent hit the frame or the engine casing when you move it
  17. kickstarts are compatible with efi but manufacturers have 'moved on' here too, they've phasing them out for years
  18. Airhead replied to rob8440's topic in General
    Robert not everyone reads noob threads let alone every new post in a noob thread ! Go ask your question in workshop...It's the title that will attract input if you know what I mean
  19. it is not possible to select gears when the engine is stopped without rocking the bike back and forth
  20. Airhead replied to rob8440's topic in General
    Greetings Robert
  21. Greetings Andy, nice to see the enthusiasm you have for your little yammy, yeah they are a solid little motor
  22. you have to rock it back and forth to be able to change gears...are you doing this?
  23. what's a verator nut? cant think why you cannot select gears though, what none at all?
  24. you only took off the gear lever...nothing else?
  25. Have you checked the oil level isnt over filled?
