Oil for gearbox and forks
we all have to learn stuff fawz, dont worry fella. Think about it...you said 'it seemed obvious' after what I had said. You just need to do some thinking for yourself, think about 'what might happen' if you dismantle things and that way you wont have any nasty surprises
Ohh one more thing, dont remove the fork cap bolts unless you have the bike on a stand under the engine, dont try this with the bike on it's side stand, or the front end will dive down and it will topple over!! A bottle crate and some wood will do if you dont have a proper bike stand, try to have it so the front wheel is off the ground, maybe put a bag of sand (for example) on the back of the seat to lift the front
yeah I'm sure 10w40 will be just fine for the gearbox no...the pinch bolts are the ones that clamp the forks in the yokes...the clue is in the name. You fill through the fork cap bolts. Take care when removing them, they are under a little spring tension Get a friend to hold a container close to the drain holes, pull on the front brake and pump the forks up and down until no more oil squirts out, thats the best and easiest way to drain them, just do one at a time and then replace the drain bolt
- HI
- sorry to be a pain
sae 20 will be fine fawz I'm sure why are you messing with the pinch bolts then...isnt there an oil drain bolt on your forks?
HI
C'mon mike lighten up...It's only a typo! Change the 'in' for 'I'm'
HI
Greetings Ronnie hope you get the DTR sorted they're great bikes
DT R 125 CLUTCH
did you make sure that the clutch friction plate with the larger internal diameter was installed as the 2nd one in...along with the rubber damper ring?
xt250 6v 12v Conversion?
I edited your subject title, It may better attract some help here
Happy valentines day (bit late...)
not late enough
loading pictures
when you get back to your post, dont press image icon, just paste the tag you copied straight to your post
dtr power valve question
Whatever you do, ...dont stress the servo by over tightening the cables
align the 'U' cutout in the pulley and the 4mm blind hole in the cyl head (this should happen after the cleaning cycle) turn off the key. Now the PV should be fully open...exhaust port nice and smooth right to the cylinder
Yamaha DT250 MX 1977
Thats looking great John, bet you're glad the weather has been so mild lately
FS1E " s on ebay,
one last fling before the mobility scooter
Back on a bike
welcome back bob, thats a great little 2T to come back on
XV250 93 model wont start
I'd say that even though the neutral light is working, the signal from the neutral light is detached from the ignition module?
aerox 50 rossi 06 wiring problem any help be great
possible a shorted rectifier
Antifreeze Coolant smoking out of my Motor/Exhaust
Yes, get a proper yamaha one too , not one of those cheapo painted aftermarket jobbies
Head gasket? What does "stopped at a robot" mean then?
robert didiana here..
Greetings.Robert
Newbie on a yamaha
Greetings Jay and
I'm only kidding, She looks great. Nice one
Ha I knew you were up to something John, like you really need another bike
