Airhead
  1. surely as 'cynic' said you can use the old engine, with the head/barrel/piston from the new one? anyway, as you have suggested, you may be able to use all the new engine but with the rotor/stator and carb from the old one...made any decisions yet?
  2. I'd be thinking along the same lines as you mikki
  3. Welcome back to yamaha Andy
  4. cant be that far out then, isnt there an inspection window or a dipstick on this bike?
  5. yeah thats right but really theres no need for that bit of kit, if you think about it it's main benefit would be on a car where you cant push the brake and work the nipple at the same time!
  6. so you put a litre in? how much does it take?
  7. pump the lever several times, when you feel some resistance (ie before it hits the handlebar), hold it there and then and only then undo the nipple and allow the lever to hit the bars...hold it there, close the nipple...and so on, you wont have to pump the lever following this, just do it as you have been doing.
  8. did you overfill it then?
  9. I wouldnt use the dead battery, you may overload the rectifier / charge coil
  10. check the buls with a multimeter edit: i meant bulbs !
  11. yeah the battery acts as a bit of a 'sink' for some of that high voltage, perhaps running without it overloaded the regulator and blew the bulbs?
  12. Great pic of your bike in the Derbyshire hills shaun
  13. thats pretty much normal, sometimes you can see more move though if the clutch has the moulded rubber spacers in it
  14. my suggestion is keep the throttle closed when kickstarting her
  15. Thats right
  16. Disconnect the cable, use your hand to push the operating lever until it shows resistance. at this point the pip and pointer should align, use the adjuster screw to achieve this. when that's done re fit the cable and set the free play....job done
  17. try a squirt of oil down the spark plug hole, it will restore compression to help start the bike
  18. Well done she's coming along nicely mcf
  19. err what do you mean the tyre dislodged from the rim...if you're riding that hard off road have you considered using rim locks?
  20. G'day openroad, Greetings and plz leave the 'new members' section for intros and welcomes/general chat and post your Q's in the appropriate place (workshop?)
  21. yes of course you will tom, you'll need some free cable can I ask why you want to do this? It's not meant to be dismantled on a whim...only to change a cable
  22. use paint stripper on the caliper...though that stuff isnt up to much these days! which may be why no one responded, y'know telling you to do something that no longer works...try to keep it away from any exposed rubber parts. as for the casing, why not re-paint it and maybe stick something on to take the worst of what the mx boots dish out?
  23. is it a cylindrical box tom? if so the end with just one cable pops off...try warming it with a hairdryer?
  24. nice looking pipe, reminds me of the one I had on mine
  25. what do you call a dear with no eyes? me neither Hey I meant ask your neighbours (the ones next to you) how to make your bike LOUDER
