Airhead
  1. If the gearbox is full of fuel, is there any chance the carb float valve is passing and fuel enters the crankcase constantly , given that the petrol tap is passing or switched on? Also check the fuel overflow tubing is not raised up higher than the spigot it attaches to, or crimped/blocked
  2. Airhead replied to s900t8v's topic in Projects
    you dont need to buy plates if your plates are within spec...use a vernier and check they are out of spec first before you buy
  3. is the clutch slipping? check the oil level and that you used proper bike specific oil, as in not car oil
  4. Airhead replied to s900t8v's topic in Projects
    If it runs well with points why change it?
  5. Airhead replied to s900t8v's topic in Projects
    Ive got port map diagrams for77DT125F DT125MX 77DT175 and DT175MX, you'll have to give me a week though to scan and post them up
  6. "Picture yourself on your deathbed...How many of us are going to say to ourselves, Fuck it I should have spent less time riding and more in the office? " http://youtu.be/LRQyEBY5YjQ
  7. Airhead replied to s900t8v's topic in Projects
    shouldnt there be a seal retainer plate keeping that RH seal where it should be?, there is on DT's
  8. Yep, bump start it backwards, than ask your mate if he wants a race
  9. 40 kicks! that aint right is it.
  10. I have evolved into preferring paint myself, but I am in the minority from what I've seen on peoples resto's
  11. Great intro Andy, not much left out there fella wow the Fiat is a stunner, I can see the DTMX is going to be very smart too now yeah the regulator is mounted on a plastic battery box? so a short black wire with a ring terminal around the mounting screw is the way forward
  12. could it be a slipping clutch, what oil did you use?
  13. is your gear lever hitting an engine casing therefore needing to be moved on the splined shaft?
  14. Yep greetings rokkchic, was down your way last weekend a...derby rugby club at a rally welcome to the yamaha family
  15. could have got cleaner just as good from any pound shop, that abrasive paste stuff in a little tub
  16. £14.99...more money than sense! lol
  17. there are always clips
  18. Get yourself a workshop manual steve
  19. Greetings mate
  20. yes arrow and dot is on the DTR I think
  21. give the cable some slack, use the adjuster at the lever
  22. you assembled it wrong steve, was there some rubber damper rings between the plain plates? my guess is that you put two of these in next to each other instead of either side of a plain plate...just a guess though but you'll have to strip it down again BTW did you put all the plain plates in as you should...theres a right way to do it...know what i'm talking about?
  23. Airhead replied to Sacha's topic in Projects
    Good to see you back Sacha you've been missed, so let's see the finished DT then
  24. try fowlers of bristol, or Granby in Derbyshire Nick
  25. sounds really nice John, shame it's not an RD eh?
