Airhead
  1. Greetings Farrell, good luck no thursday fella, not that you'll need it eh
  2. It's the bulb capt, you were probably rough with it.
  3. Great stuff
  4. I suggest you dowload an owners manual for a YBR125, perhaps that will give info on certain things...the battery spec for example Here http://ymenvom.crestec.nl/new/manuals/U5YJE0.PDF
  5. 380 dollars for a kickstart lever! LMFAO http://www.ebay.com/itm/281449738118?item=281449738118&viewitem=&sspagename=ADME:SS:SS:GB:3160&vxp=mtr
  6. Airhead replied to g1hsg's topic in Reviews
    Great report mate, enjoyed reading it. for those of us who dont know...It would be best with a couple of pictures I reckon
  7. Airhead replied to Kevinp4966's topic in General
    blipping the throttle is always a good thing when downshifting, much less clunky...experiment...you'll see what I mean
  8. Airhead replied to s900t8v's topic in Projects
    you wont need to por the tank unless it's leaking The stones and vinegar is a good idea followed by a good dry out and again followed by a good rinse out with rust converter such as 'Jenolite' if you can get that in Oz.
  9. Sure you should get a manual but I would think the problem is more likely fuel than valves. Adjust the idle speed using the idle adjust screw, generally it's big screw and often has a knurled edge to grip between your finger and thumb...cant mistake it Clockwise to increase engine speed and you shouldnt have used the cable tension to achieve this, the cable needs a smidges of slack with the throttle closed
  10. Airhead replied to s900t8v's topic in Projects
    Ahh right, I thought you'd used it as well as a gasket
  11. you need to find out what the fixing hole centres are as compared to your's ?
  12. Airhead replied to s900t8v's topic in Projects
    cant understand why you glued on the clutch cover? even more so when you have to open it again soon
  13. blocked filters? check you flow rate NEO
  14. Hi! I just signed the petition "Peak District National Park Authority: We call on the Peak District National Park Authority to stop imposing Traffic Regulation Orders on our Green Lanes" on Change.org. It's important. Will you sign it too? Here's the link: http://www.change.org/p/peak-district-national-park-authority-we-call-on-the-peak-district-national-park-authority-to-stop-imposing-traffic-regulation-orders-on-our-green-lanes?recruiter=153298545&utm_campaign=signature_receipt&utm_medium=email&utm_source=share_petition Thanks! Paul
  15. waste of time, money, weight
  16. good suggestion tommy but it might not be the old bullet style connector so perhaps not that easy?
  17. 2A8 is a 125 engine casing, has it got a 6 stud 2A7 Barrel (175) ?
  18. Dates normally posted in January mate
  19. Hi Mike, Yeah you see the tubular junction box where one becomes two? well the top of this will pull off, It's quite stiff though. There's a slider inside of the tube with recess's for the various nipples now about that intro?
  20. it could simply be that your battery has died of old age, not beyond the realms of possibility given the age of the bike
