Airhead
  1. Airhead replied to Airhead's topic in Yamabyss
  2. Airhead replied to Airhead's topic in Yamabyss
    Thats the spirit
  3. Airhead replied to Airhead's topic in Yamabyss
    And see that you dont get too rebellious Blackhat250
  4. Airhead replied to ciderking's topic in The Bar
    Hello, mines a pint, As for photos I was having trouble with this, 'Goff' put me right, use photobucket. upload your piccies to there then copy the IMG link and post it in a forum message. Cheers
  5. Hi you could try M&P or MPS, look them up on tinternet, They do hundreds of levers for many bikes, cheap too!
  6. Or indeed, mine?
  7. Ditto from me. And if i'm honest Im sorry but when i read the title of this post i didn't know WHAT to expect........ I bet this post gets a lot of views...
  8. Sounds more like a heat problem to me, when the engine gets warm something gets open circuit, not familiar with model though, any ideas Drewpy?
  9. When you say you have no spark I assume you have the plug removed and you are cranking the engine with the ignition on and the plug securely grounded. Can you get hold of an analog voltmeter? set to 12VDC, Connect the negative lead to battery negative (Or chassis) and connect the positive lead to the coil low tension connector without disconnecting the wire from it, when you crank the engine I think you should see the pointer of the meter 'pulsing'although I must add here that I'm not an expert.
  10. Hi mate, any sign of life from the battery, lights, horn etc, Is the engine kill switch off, And sorry but have to ask, is there fuel in the tank?
  11. Airhead replied to smf_12's topic in The Bar
    Hello and welcome How about a Bandit? Aagh I mean a fazer
  12. My bro in law's one of them, dont tell him I laughed.
  13. Youre absolutely right Yamahead, but sometimes you offer an olive branch and just get beaten about the head with it, and so it goes...on.....and on...and on
  14. Airhead replied to r1mick's topic in Yamabyss
    Haaa ha ha ha, just found this, Ace
  15. Dont know if i can worm out of doing the bathroom, if i can i'll let you know , it would be good to meet up with you and Drewpy
  16. Some bikes are just like that, sometimes the oil is too thick, check the right viscisity oil is in there, and sometimes it helps to rock the bike back and forth while trying to select neutral.
  17. No he's quite entitled to stay here, it's not just your puchbag, and there's nobody better at putting another country down than you Mr P, You could give lessons in it! Go play with your gun.
  18. hello Jody, Never heard of a maxim 400, but if no one comes up with anything you might have to get a silencer off another bike (might mean a bit of trawling) to fit yours, or adapted to fit, good luck
  19. Dont panic, just bleed the clutch if its a hydraulic one!
  20. When the stand is up, make sure it activates the switch plunger, If it does'nt, then hold the plunger in with something and try again
  21. Airhead replied to Bear's topic in Naked
    Bye
  22. Airhead replied to DeBortole's topic in Classics
    I'm only joking, Thats a nice bike you got there, love to see these specials, (more interesting)..
  23. Airhead replied to DeBortole's topic in Classics
    Well Hello
  24. Airhead replied to Bitripple's topic in Naked
    Hi Ive got a suzuki bandit and its just the same, two headlights, one for low beam, one for high beam, plus a small running light. I expect that other R6 owners will soon confirm that yours is correct.
