Airhead
  1. You didnt state this but I assume you were stationary with the engine off. If so it is usually quite difficlt selecting all the gears unless you rock the bike back and forth.
  2. Airhead replied to vijay RX100's topic in Yamaha Workshop
    Theres one Right Here Vijay
  3. Yes nice, What kind of Yamaha did you say it was??
  4. Airhead replied to Togusa 125cc's topic in General
    They all smoke a bit, how bad is it?
  5. Does this help? Linky
  6. You must have mis-interpreted my advice, hope it mends soon, i'm sure the nurses will take care of your every need..
  7. No its all been a BIG mistake, HEeeelp...Call them off or i'll sue
  8. Hi and welcome, Not familiar with the bike, But I'm wondering if the white oil you say is oil/water emulsion, could be cylinder head gasket. Is it a watercooled bike and can you see any oil in the coolant expansion tank?
  9. Wasnt me your honour...Never said anything Hmm well what a surprise...NOT
  10. Wow, have you got a firearms licence for that exhaust?
  11. Airhead replied to jrhendryx's topic in Classics
    Yes you will need a valve spring compressor, gather all your bits and pieces first, valve seals, lapping paste, sucker thingy for lapping valves, valve spring compressor, etc, not done any of this kind of stuff since i was a kid, so ask others for tips. You might find info on internet, or workshop manuals etc
  12. Everything has a part number, get your dealer to order one for you, (its a 2004 bike, so wont be discontinued)
  13. No its the other way round, larger front sprocket = Faster top end, (Except the engine hasnt got the power to pull it ) Smaller front sprocket = Faster acceleration and slower top end
  14. Airhead replied to jrhendryx's topic in Classics
    So if you do decide to change the seals on the valves, You will no doubt find the exhaust valves very dirty and carbonised from all this burned oil so you will need to remove and clean them. Also gently lap in any valves ypu work on!
  15. Quick answer is, ..Have a look on the casting near the fear lever, sometimes you will find something like 1-N-2-3-4-5 etc Soungs like the clutch plates need replacing!
  16. I'm happy using a rucksack to carry my butties (and stuff) in, cheaper than a rack and topbox and dont spoil the look of the bike.
  17. Airhead replied to jrhendryx's topic in Classics
    This can be the seals on the exhaust valves, as the exhaust gasses become hotter they start to burn off some of the oil leaking into the exhaust port, but may not burn it all hence the oil in muffler. however I dont thik it is the only problem as this shouldnt make the engine die off, so could be coupled with any one of the other possibilities. On the other hand leaking seal on inlet valves usually cause lots of smoke right from go, becoming less as engine is run so could it be rings and exhaust seals? Edit.. I've been thinking about the dying off and changed my mind there, I think the hot gasses and flames are igniting the oil and the resulting smoke is getting into the cylinder because the exhaust valve is open which is in turn affecting combustion I expect that from cold start there is no mis-firing as at this point the leaking oil is not ignited
  18. I agree with you on that, carburettors are indeed a fascinating invention. I see what you mean about some confusion creeping in with the two needle's youve mentioned Regarding your float needle, Its important that you set your float height correctly using a vernier caliper is the best way. Having done that you should never see any overflow, If you do you will need to replace the float needle valve and possibly the seat too. If fuel level in the bowl is too high it richens the mixture causing excessive fuel consumption and poor running. On the other hand, a low level will lean the mixture and could cause flat spots when accelerating out of turns, or in extreme cases cause overhating and possible seizure Regarding the hole in the carb barrel nearest the manifold side...Many carbs have a two hole idle system which gives better low speed and mid range throttle response than the simpler one hole type. At very small throttle openings, the bypass hole and not the pilot hole actually provides the engine with fuel. Instead the pilot hole acts as a supplementary air bleed to further atomise the fuel airafter it passes through the idle jet. As the throttle opens wider, the pilot hole too begins to spray fuel. This serves to supply the engine with additional fuel until the air speed throgh the carb increases enough to start the main jet and needle valve flowing fuel into the engine This is a good book if you really want to unravel those mysteries, .... Performance Tuning in theory and practice Two Strokes A. Graham Bell ISBN 0 85429 329 9 Oh and another thing, Look what I found Here And its in Canada too
  19. You are talking about the cooling fins of an air cooled cylinder and cylinder head, rinse, spray muc off, brush it in and rinse off, much as you are already doing. Also.. Newly painted exhaust
  20. Airhead replied to AdZr's topic in Naked
    It might be if its easy to do, or you could possibly detach it from the intake rubber if thats easier, On the other hand the easiest thing is to leave it alone and dont go overboard shoving the bike around, its only to aid evaporation and expulsion of any fuel build up...You be the judge!
  21. You seem to be going to an awful lot of trouble to overcome this supposed vacuum in the tank. After all this I hope it works for you but I have my doubts. But whatever you do, Dont be tempted to just run down your fuel level, open the filler cap and stick a rag in there to prove or disprove the theory!
  22. Airhead replied to AdZr's topic in Naked
    [quote name='AdZr' date='Sep 1 2008, 01:03 PM' post='62814 do you know if the engine has a drain plug for the crankcase No I dont but I doubt it, Theres usually only a drain plug for gearbox oil. I would turn the engine a little, by Having ignition off, Fuel tap off, remove plug and push it along in 4th gear, dont have to do much as dont want to be sucking more fuel from the carb.
  23. Hello and welcome Street Hawk, I use muck off for any particularly dirty areas, leave it to soak in a little, Also some added to warm water also for washing down paint work To remove that initial Fling off from a lubed chain, WD40 on a rag, just give the rim a quick wipe round Solvol autosol and elbow grease for stainless header pipes...Never use it on chrome though, just soap and water for that. Furniture polish for paintwork, spray it onto the duster away from the bike, you dont want to get it on your disks
  24. OK this is what I do...When the chain needs a re lube I shock horror Spray WD40 on a rag, not on the chain, And use this to clean the chain rollers and side links. When its all clean and shiny i then spray on my chosen chain lube. What im trying to say here is that WD40 used sensibly is not the demon its being portrayed as IMHO
