Airhead
  1. You should stop riding it straight away, sounds like something has come adrift, I suggest you check the generator flywheel hasnt come loose
  2. The pilot jet is item 2 Here You need to unscrew it from the carb body and confirm it isnt blocked, This jet is the one used to start the engine, as well as part throttle opening, If you hold it up to the light you should see a hole through it (not blocked), use a magnifying glass if necessary
  3. Airhead replied to Goff's topic in Yamabyss
    Hmm, Wonder what happened to MikeyDTR, he seemed such a nice lad
  4. Did you check the pilot jet was not blocked, Can you see daylight through it? is the plug wet?
  5. Go to dealer with your exact model and engine number, I personally dont like using bolts because studs are fixed and the bit that takes the wear and tear is away from the internal thread in the cylinder head, much better that way IMO
  6. Can be difficult to get to the bottom of these problems, But to make a start..have you ridden through much rain or puddles etc, seems rather sudden. I think you should remove the generator cover because thats where the CDI coils live, see if its wet inside the case and spray throgh the flywheel slots with WD40 then try again
  7. Hello and welcome DereK
  8. On first looking it should have studs, Its a newish bike so you would be able to buy them from Yamaha agent, or if you know the length maybe from engineers suppliers or look in motorcycle mechanics magazine see Here
  9. Can you fit studs instead of bolts, Loctite them on the head side and use nuts and spring washers on the pipe clamp.
  10. Awww, Shut up Matt youre embarrasing me, For once I got something right Eh. Glad it worked. Or to quote another of our members Thanks for the Big Up I Know a lot about not much and not much about a lot more But youre welcome, if it`s of any use (R1evad)
  11. Airhead replied to shithead's topic in Yamaha Workshop
    Hello might be nice!
  12. I think iys more likely an ignition fault, Get yourself a strobe light and do an ignition check, Have you got a Haynes manual? I think it might be useful
  13. Nooo replies everyone else!!! Make a lovely avatar
  14. Dont forget now...Keep us posted, Say every 500 miles or so
  15. Wow looks too good to hide Oli
  16. Airhead replied to Parsley1000's topic in The Bar
    Welcome to the forum Parsley, As a mechanic your input will be really helpful
  17. like This, Your local bike shop or mail order such as M&P etc should have them
  18. Chris the bike is a fair bit older than you and probably hasnt been looked after properly
  19. Airhead replied to Dave C's topic in Yamaha Workshop
    See...I was wrong again!! Thanks for letting us know Dave.
  20. I agree Goff, all sorts of things have been dug up and answered recently, But three years! And todays top poster is...?
  21. Hi Ian, Yes Its stuck due to lack of use, I recommend you start it up and let it run, Get the motor really nice and hot, This will thin the oil down, When its hot keep pulling in the clutch lever and blipping the throttle, Crossed fingers this mught free it If this doesnt work re try the rocking back and forth in 4th gear with lever pulled in, but this time with hot engine. If its anywhere near due an oil change it would be wise to do it sooner rather than later if its been stood,
  22. Nice to see Justice done oldtimer Now stick your chest out and snatch i off em!
  23. Just curious guys, I ve never had a power valve (Old school), Why would you want to do this, surely its supposed to be automated? Come on ..enlighten me
  24. Geoff, you wanna get yourself some nice wide chicken strips...Stops all that
  25. A few years ago i bought a new Honda NX650 dominator, similar to your XT, Loved the look and ride position, but didnt like the ride, too long legged, crap commuter, slipping clutch all the time in traffic etc, Then gota Bandit 600 and absolutely love it, It does everything well, Fast, slow whatever you want and it looks good too so...When you get this your single pot days may be over, so Smooooth! No idea whats going to fall of it, But reckon you'll love it like I do mine
