Airhead
  1. Can you take the fuel pipe off the carbs to check the fuel pump is working?
  2. You wont have a problem anyway OT
  3. Worth a try here maybe woody
  4. Try a new plug cap on the bad side
  5. Assuming its a 12v bulb, you will get one from any car accessory shop, or bike shop or possibly as you said, petrol stn.
  6. Airhead replied to Morgy's topic in The Bar
    Dont you sleep then? or does it tick over in the lounge all night? Anyway, yours is a vacuum tap so doesnt count
  7. Fairinuffsky, but they are a one off for this bike only i think, so you will be lucky if they do them! Edit, Did have a look and no surprise...They aren't listed.
  8. Didnt know you had a DT175MX!! Do you have ebay in Oz?, they come up now and again on ebay here!
  9. Airhead replied to ShoKz's topic in Yamabyss
    I know a good paint sprayer, distance no object
  10. You can wheelie almost anything if you give it enough revs sit well back and dump the clutch in first gear, but it will only impress the very young And if you dont get it right you may end up sat in the road minus bike, but hey nothing ventured nothing gained eh! **I cannot be held responsible for any action taken after this message has been read**
  11. Hi Hasan, My DT175MX has all those little problems too, max 65- 70mph, 6 volt electrics and like yours a fully functioning oil level light, And....I love it! As for doing 75 on one of these, I say...Dont believe all you read!
  12. Airhead replied to Goff's topic in Yamabyss
    I think you missed yodas point there, valve inners can be replaced with no expense, but valves cut through can only be replaced at great expense!! Not that i'm suggesting....just...clearing up....a...point.
  13. Considering the problems with it I think you paid a little too much for this, If I were paying that amount of money I would be expecting the bike to be in good condition with all the equipment functioning properly! Right, having said that! Its difficult to comment on the head lights, I expect the lights now fitted arent proper vehicle lights and will not give the right beam pattern, I think you should put back the original headlight ASAP, Mirrors are a benefit to the rider, I dont think they have to be fitted by law, but riding without any at all is madness and dangerous, so I reckon you should buy these also and a speedo cable, just get it all back to standard, i dont think your GPS speedo will be acceptable if a policeman pulls you over!!
  14. Yamaha dealer should have no problem supplying that.
  15. Names...We want Names!!!................................................ McWho?
  16. Airhead replied to R1racer's topic in The Bar
    Hello and welcome Daz
  17. Yep thats exactly the same set up as mine, you will also have a pilot light in your headlamp that doesnt need the engine running. The headlamp main and dipped are running from the magneto.
  18. Hi Mike, Is that all lights including tail lights and instrument lights?? Dunno the specifics of your RXS but my DT headlamp needs the engine running as it is powered from the magneto but tail and(headlamp, pilot) and instrument lights work off the battery. does your horn work(or try to work) from the battery ok without the engine running?
  19. An introduction?
  20. With the nut off, the flywheel should be still fixed in the correct place because there will be a keyway holding it fixed on the shaft. You would need a puller to get it off the shaft so removing the nut would not have caused this problem. put the nut back on its not that thats the problem!
  21. Airhead replied to Morgy's topic in The Bar
    You should get in the habit of switching the tap off when bike isnt in use, all taps were like this before manufacturers saw the light, it only takes a leaking float needle in your carb(s) with the the tap ON to potentially have petrol running into your engine, this petrol can seep down past the piston(s) into the crank case or sit on top of a well sealed piston, either way it could be very interesting when you press that starter button!!!
  22. Hi Steve, post some pics of the problems!
  23. Airhead replied to nickg12's topic in The Bar
    Sounds like your carbs are flooding, first check your petcock is working properly, if its a vacuum operated one and you pull off the gas feed pipe from the carb then it should not keep running out of the pipe unless you switch to prime position. its always best to know this is working because if your carb needle valve is leaking as well, serious damage can result from a combination of leaking petcock and leaking carb float needle. It looks as if one or more of your carbs are overflowing so you should check the float needle valves are clean and not worn, if they are damaged you will need to replace them.
  24. No problemo mr mop, make sure your gearbox isnt over full now though!
  25. What size socket fits...13mm? The torque setting for my 175 is 18lb/ft or 2.5 kgfm, this has 8mm threads so 13mm socket (sometimes 12mm), these settings will be fine for yours too assuming they are the same size studs.
