Airhead
  1. Airhead replied to a post in a topic in The Bar
    Good news Geoff
  2. Does the tap have a 'RUN' and a 'RES' position? When when you run on to RES you have approx 2.5 litres of fuel left You must remember to switch it back to RUN when you fill up....Hope this helps
  3. This is bad news, not familiar with your bike but ive learned from previous posts that theses bikes struggle to haul their considerable weight around, A knocking noise is a bit of a worry, tell us you didnt buy it private sale and then take it back to the dealer to fix...Four days!!!, you cant be that unlucky surely
  4. I mentioned FZR600 a, because its the only diagram i could find b, so i thought they...just might be similar who said i was looking at a FZR1000 diagram?
  5. Yes i followed a FZR diagram Jim, like the title of the post...FZR1000
  6. Try some new plugs and caps, also give the HT leads and coils a spray with WD40.
  7. If its the same as FZR600, the lights are fed via the start button switch, from battery through fuse red/yellow wire, into start button when button NOT pressed , back out on blue/black to feed high low light switch.
  8. I cant tell you to take risks with your money, but i can tell you at £34 if it were me i probably would, the only problem is, it it doesnt work is it the new CDI or is it something your shop / garage has missed?
  9. Airhead replied to bradley's topic in The Bar
    My bikes 15BHP...Its a man's bike...15 of em... all at the crank... fck it! New carb ordered new reeds waiting new expansion pipe waiting modified air box waiting ported cylinder waiting
  10. Airhead replied to fostersice's topic in General
    PMSL...
  11. Airhead replied to bradley's topic in The Bar
    Ive had an idea, buy some bike mags with tests for this bike, they might shed some light on it. Shokz is right, manufacturers sometimes quote BHP figures at the crank, not the wheel. I think the guys at the dyno session should have explained things more though rather than just taking the money and saying nowt!!
  12. Its the dry battery and elevated voltage if there is, thats causing bulbs to pop
  13. i'm thinking like you on this, Stick a multi meter across the battery terminals at tickover (as in traffic jam), see what you get here!
  14. Hi and welcome, First start with a workshop manual, there will be lots of good info in there!
  15. Could this be a vision of the future, a la flight simulater Good Luck...
  16. Airhead replied to willis1123's topic in Yamaha Gallery
    Two superb pics there, where were they taken...Wales?
  17. Airhead replied to TazR6's topic in The Bar
    Dont have a honda, and theres nowt lightweight about riding a pushbike 14 miles a day over Mottram moor...lightweight is using the motorbike...hopefully when winter is over i will will be a bit lighter though
  18. Airhead replied to pilninggas's topic in The Bar
    Err apart from Drewpy...have you seen any of us out and about???
  19. Good point that!...well worth a check, does make a big difference.
  20. Aah i get it, its not leaking its passing, you neet to strip it down you might find some rust or crud has gotten under the diaphragm!
  21. Looks like a white RD where im sitting, so thats where the sunshine is then
  22. A shut off valve after the petcock is hardly gonna stop the petcock leaking...is it?
  23. Me neither
  24. Airhead replied to TazR6's topic in The Bar
    Me too mate, away goes the bandit and out comes the ..........................bicycle!!!
