Roughley's Toy Run 7/12/14
My computer cant handle the link...when is it...Sunday?
SUNDAY THE 30TH of november.
It's 'dog n ducked'
- Bikers are like Drummers
Vesperados Toy run
Have a good one drewpy, I'm off to the NEC bike show
dt175 clutch problem
It's not an oil pressure light, It's a 2 stroke tank oil level light, comes on in Neutral and if the level in the tank is low...no bother if you're pre-mixing Car oil has additives that might make your clutch slip...bit ironic that eh
its just the plates stuck together. Get the engine hot. Then select 6th gear and with the clutch lever pulled in try pushing the bike it might free them. Plz post q's like this in 'Workshop' Ohh and how bout a little intro in 'New Members' ?
XVS Dragstar - Destroying CDI?
unscrew the plug cap and chop off 10mm of HT lead from the front cyl coil
3rd DT175 Restore - 78 model
Its all a bit of a con, NEO sussed it he's sharp that one
Where is Elvis
wheres Elvis, wheres Bippo, wheres Cynic, whares DT502001 ????
- Loomies... saved?
Somebody stole my Brake Disc Bolts!
you're missing the point, if it had a big chain/cable clearly on view...perhaps they'd have walked on by an alarm might be good too, it all helps if your parking place isnt secure
Airhead , a bargain for you
hmm i'll have to get mine listed
dont buy cheap, got to your yamaha dealer and order the proper parts, they will be high tensile strength and you should fit proper bolts to your brakes, what year is your ybr ? hey I'm sorry to hear about your predicament, thieving bastards, try to get something other than the disk lock, a big cable/chain lock as well ?
Sr125 1997
dont know much about these things but my thought are...does it have a balancer shaft?
carb jetting
Wide Open Throttle
Carb Advice
just leave the sparkplug out, it'll all evaporate over a day or two
Key getting stuck in ignition
might not be enough just to wet the key mate but try that first eh?
I do, never had any bother by doing so either
Ybr clutch problem
Check your nipples, have you still got two?
Carb Advice
That'll be the problem yes it'll suck loads of fuel through because the small drilling in the end has gone
help me identify these carbs 1987 FZR750RT ?
best I can do is ammend your title Mark
hi all
Greetings Naomi, you were done there !
Carb Advice
tell you what, get a jam jar with a little water in it, take the gearbox breather tube and put it beneath the water level and start the bike, look for bubbles or the water going down...that'll test the RH seal, It's an easy enough test to do and I'm not happy about the smoking just yet but it could be the smoke they all put out when cold...just seemed an awful lot in the vid
Carb Advice
john, yeah the tube is shorter but no worries because the vacuum will draw fuel up the tube in the bowl anyway provided the seal around the tube is intact. Now this syringe...How do we know that the rate of descent isnt absolutely normal, I've never heard of anyone using it as a health check tool for an engine? and didnt blackhat say his 250 did the same, dont forget the syringe doesnt hold much fuel in it's small diameter. Cant see anything wrong with this carb, it looks in v good condition to me. What about the smoking, boy does that thing smoke!!! this could cause rough running as I think I said earlier. The RH crank seal may be fubared for all we know...does the smoke smell bad bad bad yuk...or a nice 2t oil smell? Take out the dipstick, can you smell petrol in the oil?
Carb Advice
well I never, you'll need one of these then and some gaffer tape
