Airhead
  1. The link i sent WAS the uxbridge one Mines a 175mx The company youre looking for is Redrose, they have a website, its well worth contacting them yes. Blackhat250 has one of them american 400's, he imported it, took best part of a year to get it though, have a look in gallery you might find it
  2. Anyone going? http://www.bikeshowseurope.com/index%20ONE.htm
  3. wow a scientific answer, i salute you pilningas, but i'm with Goff, it does look rather shite and best left to posers and the race track then IMO
  4. Could it be a serious lean mixture problem, possibly due to a split carb manifold or something?
  5. Whats the difference between the custom and the classic, are they both uk models?
  6. Hi John welcome to the forum fellow DT Fan, shame you missed this one Here but good luck with the search, our Blackhat250 is looking to sell his DT250 i think!!
  7. Airhead replied to KLB007's topic in The Bar
    That advanced riding would benefit you yes, the more you do the better, watch out for metal manhole covers on bends, watch out for banding where repairs have been done and watch out for blind car drivers, i reckon our Goff would love to talk about riding safety stuff because she's well clued up on these things
  8. A performance upgrade? and i thought it was so the fairing didnt melt, seems daft though since engines need to be cooled somewhat, so why insulate the exhaust...so thats my view no pro just a con unles youve got scorched fairing paint, i'm here to learn though anyone??
  9. Airhead replied to KLB007's topic in The Bar
    welcome to the forum and to biking Kev, glad you saw the light, not many make the switch so late but thats their loss, be careful while you gain experience and if you can try to get out with others, you will get experience and have fun too, bikers are a great bunch as i'm sure youre learning
  10. Airhead replied to EPP's topic in Yamaha Workshop
    There should be no drag with your brake, check that the pads are free to move inside the caliper and that the anti rattle spring is fitted correctly and has not become trapped anywhere between the pads and the caliper.. Try using a wood chisel to scrape any rust and old brake dust out of where the pads sit and check for rust build on the edges of the pads
  11. Pictures might help and where are you? or where is it?
  12. As its only 11 years old why dont you buy from your Yamaha dealer?
  13. The easy way is to pull the cable up fron the engine case it will stop when the pulley is fully open, or you can pull off the pump cover and push the pulley round with you finger, either way allow the engine to tick over and hold the pulley at max position briefly, dont over do it though its just to make sure the oil is there from the off
  14. It shouldnt be necessary Steve, that has never been a part of running in even a brand new engine, the crucial things are that you did a good engineering job when you assembled it and as has been said many times jetting and mixture is set correctly, if you are putting your old 50cc pot back on i suppose youre jetting must me somewhere near as its as it used to be, just make sure the air mixture screw is set right Edtt You should wipe round the bore and piston with two stroke oil upon assembly On first starting your bike you should force the pump stroke to maximum without opening the throttle to maximum briefly to ensure oil is there immediately.
  15. you get an old spark plug and hammer out the central electrode and ceramics, you are then left with the threaded part. Drill out the threaded part to the same size as your dial gauge spigot, Then drill and tap for a 4mm screw into the side and fit a screw this will hold the DTI tight. you may or may not need to screw in an extension piece to reach your piston.
  16. see Here item number 22
  17. cant you see a drain plug in the float bowls?
  18. Why dont you take the bike in to get it sorted if you cant do it yourself or do you really want to have a do at this? have you got the know how to remove the carb and float bowl to see what size main jet youve got?
  19. Tank breather?, try the idle thing with the filler cap open. Fuel filter, is it blocked?
  20. Havent got experience of restricted widgets, but dont they put a spacer above the carb slide, thus preventing the throttle from opening fully?
  21. Theres one Here its not too bad a price as described in good condition, most are pretty poor condition!
  22. Looks to me like the carb is a DellOrto Type PHBN 16 NS/1 with a standard mainjet of #88 Go to your local yamaha agent and order the next two sizes up on this size
  23. That will make it richer but only in the mid range, you should get the main jet right before you look at needle height
  24. Take a look at your main jet, note the number of it and also the general size and shape of it, then have a word with Steve at motocarb, tell him what youve got now and why you want a bigger jet, see what he suggests, if its a new exhaust it will be 1 maybe 2 sizes bigger i expect
  25. Clear lenses are ok if you can get them, you fit amber coloured bulbs inside.
