Airhead
  1. Yes fix it with a patch and buy a new tube too then you will have a spare, get some proper levers Here like these
  2. Airhead replied to Goff's topic in General
    Hey...I got one of them gooses too
  3. Airhead replied to mikey bey's topic in The Bar
    Welcome mikey.
  4. Ive never seen that, theres hours of fun to be had there
  5. Pushbike levers are not strong enough you will bend them. Dont forget to tread on the opposite side to where you are levering to get the bead to the middle of the rim, you will need to buy a motorcycle puncture kit (or a new tube)
  6. How come you get all the bad luck then? Taking tyres off is not an easy thing to do and putting them back on is even harder, rather than spend ages explaining i will scan something and email it you, PM me your email addy
  7. Airhead replied to the beast's topic in The Bar
    You asked this yesterday and i answered!
  8. Many dealers would just sell you the grips without asking, then after you go to the trouble of fitting them (which sometimes means modifying the throttle grip tube) after doing all this you find your battery going flat, seems he did you a favour, perhaps you were lucky he saw your bike after all!
  9. to the forum spiderman
  10. Airhead replied to pilninggas's topic in The Bar
    Always nice to get a new bike, lets hope for a great year to ride now eh!
  11. Airhead replied to the beast's topic in The Bar
    Hello and welcome 'the beast'
  12. Worth a try, they are a massive dealer http://www.fowlers.co.uk/
  13. Airhead replied to wild foamy's topic in Yamabyss
    aye ...but Steve lives there
  14. Are you asking or saying? Have you tried Fowlers?
  15. Plug Type NGK BP - 7ES Plug Gap 0.7 - 0.8mm (0.028 - 0.032in) contact breaker gap 0.3 - 0.4mm (0.012 - 0.016in) The points gap is set at the widest opening. Removing the large plug just left of and below the points reveals the timing mark. The contact breaker points should be set so that they are just opening as the F mark aligns with the pointer
  16. I agree with all of that Darren, but i bought some acerbis ones and couldnt fit them due to the way the electric cables exited the switchgear on my bike, so it's not straightforward that you can use these either, like you say with those others you will only get a bit of weather protection.
  17. They look like poor quality after market ones, i know this because i had them on my DT, they attach by the lever pivot bolt but the pivot bolt is shouldered and is not meant to go through an extra 3mm of plastic so in my case i had some new pivot bolts made. even after doing this i still had to get creative with the saw and knife I may be wrong though as on the link you sent the mounting method cannot be seen!
  18. If there are 2 wires, unplug the connector and check with your multimeter betwee the 2 wires to the switch, STOP = 2 or 3 Ohms, RUN = Open circuit BTW, What are the wire colours?
  19. Airhead replied to 2ptjoe's topic in The Bar
    Welcome Joe
  20. Bend the little tab where the float needle valve sits
  21. How thorough strip down then, are you saying you split the cases and removed the crank? did you put the piecce of ring you retrieved first against the piece you removed from the piston, surely this would have shown if there was any more missing?
  22. You said that 3 days ago? Confused
  23. On the subject of carbs, you may find this useful Here
  24. Maybe the needle jet is worn they can wear oval which will make the bike run rich, have you stripped down the carb and noted the jet sizes and id markings and needle clip settings as is? Examinne the needle jet opening using a magnifying glass and also the needle, look for wear
  25. Airhead replied to troyboy's topic in The Bar
    Nope...Thats definitely a biker....I was in the pub this afternoon "The Shakespeare" at the side of primark, couldnt stop staring in the windows, my mind must have been playing games with me
