Airhead
  1. The 125's had a smaller venturi carb, you are looking for a mikuni VM24 for the 175, it will have an ID mark of 2H500 on it I wouldnt bother about the exhaust if you cannot see the restriction in the header pipe I dont think there will be one, the 125's didnt need restricting as the would barely put out more than 12 BHP anyhow, the 175's are only 15 / 16 BHP as standard.
  2. Why not just strip the caliper and fit new seals, do you have to keep topping up the reservoir? I'm surprised it passes an MOT test like this!
  3. Try it again, give it a good blast, seems you may have some oil in your crank cases What was the extent of your strip & clean, why did you do it, lets have some detail
  4. Poke the hole through with a pin or something
  5. Wipe off what you can, then hold the end with pliers and if you have a gas hob, burn off the excess oil, watch you dont burn yourself!!!...Then have another go
  6. pull the cap off remove the plug from the head re fit the cap rest the metal side of the plug on the cyl head turn on ignition watch for spark as you either kickstart or electric start the motor
  7. Have you checked for spark?
  8. Next time you do an oil change, get yourself a spare gasket and remove the case, then use some T - Cut on the glass to clean it
  9. Thats correct, as the fuel from the tank is used up it needs to be replaced with air or a vacuum will be developed in the tank, this vacuum would overcome the gravity feed to the carb of fuel pump. Open the cap and have a good look at it underneath, see if you can see any little holes that might be blocked up (Vent holes)
  10. What the heck does "Not turning over" mean, do you mean its seized up now?
  11. I ve been watching this thread and like you I have heard that the 125 barrel head and piston...and carb, can be swapped for the 175 versions, it seemed to me that the only thing to check is the part numbers for the crank cases, if the cases are the same, and as you have stated before the crank / con rod are the same, then this would be a good proposition, a quick look on Bike Bandit site confirms that both engine sizes use the same crank cases, therfore, theres nothing stopping you from putting the 175 barrel and carb on to your 125...is there? you can see the part numbers below. ...Paul
  12. Airhead replied to The Beginner's topic in The Bar
    Dont be so soft, I've done 125 miles os a bloody pushbike in a day!!
  13. Did you clean the screen in the fuel tap bowl, I know you said the flow is OK, but with rust particles you should have done this anyhow.
  14. Torquey and rugged, heres one to consider.
  15. Its either running out of fuel because the carb is only filling slowly......Or running out of sparks You need to find out which is the case, next time it conks out, pull the spark plug and test for sparks, it might be the pickup coil breaking down as the engine warms up, then as it cools a little works again...and so on and so on, you say you flushed out the tank...what was it like?
  16. does it have a CDI ignition?
  17. Try pulling the fuel feed pipe off the carb, open the fuel tap and run fuel into a container, you should have a healthy flow rate, check this first
  18. +1^^^^^^^^^^^^^^^^^^^^^^ Check and adjust chain slack as per spec for your bike, and give the chain a good lube
  19. Airhead replied to caroleb's topic in Classics
    Sorry i dont but I found This, perhaps the link will be a good place to ask
  20. Airhead replied to caroleb's topic in Classics
    Hi Carole, you can find out if your old fizz is still around (but not the address) on the DVLA vehicle tax site, enter the registration number there we have a member Deenjay who is big into these small yams, look his posts up on the search feature
  21. Airhead replied to mark h's topic in Yamaha Workshop
    Hi Mark, Just try pulling out the choke as you throttle up, if it works ok now , sounds like a carb strip and clean to me, make sure all the jets are clean, dont forget the needle jet and all the little air bleed holes in the side of it, you can get an aerosol carb cleaner from your local motor factors shop.
  22. Sean that bike is a credit to you well done, a quite fantastic job for a 17 year old, you get my vote, hope to see you around.
  23. Nah, go to bed OT, you'll only get a bad back
  24. Airhead replied to drewpy's topic in The Bar
    WOW..Now dont try this at home children!!
