Airhead
  1. Yamagod, is there a manual or a wiring diagram for this 1973 DT100?
  2. Not familiar with the bike, but I would assume the idle speed screw has the spring behind it and the other will be the mixture screw
  3. I suspect the regulator / rectifier, you may find This useful
  4. Looks like an interesting topic here Jason, should make a good horror story eh, Are you planning a full engine split with the cases split, possible bearing replacement?
  5. Usually a good indication that the carb needs a strip and clean, you will probably find the pilot jet is blocked.
  6. Looks nice, who's is it then? Oh and how was the show, meet any members? you didnt let us know
  7. Airhead replied to Twin Shock's topic in Classics
    ?? You leaving us TS
  8. The oil light is for the two stroke oil you use and not for the gearbox oil. There is a bulb check facility for this warning lamp, if the bulb is ok the lamp will be lit when the bike is in neutral with the ignition switch on. The oil inside the engine is purely for the gearbox and clutch, there will either be a dip stick on the filler cap or a glass window in the clutch case to chech the level there. There is no warning light for this oil level. HTH...Paul If the light ever comes on when not in neutral its time to top up, The oil light came on to warn you to top up, you did that and all is well now.
  9. No I dont think this difference is intentional, doesnt matter which groove you put them in. Cant you see any marks on the inside of the rings caused by this spacer ring (bright spots) that may give a clue as to which ring came from which groove, have a look with a magnifying glass.
  10. Airhead replied to maltatrucker's topic in Classics
    Check your jet sizes, Main jet should be 150, Pilot jet should be 50, If youre worried, you could always fit the next size main jet, it certainly wont do any harm while you run in the re bore, when youre happy with it being run in you could plug chop it later.
  11. Airhead replied to HalHark's topic in The Bar
    Maybe the tractor didnt like the look of you Halhark, glad to hear you got away with this one, Take care out there!
  12. They are bothe the same on the 175MX, place the thin spreader ring under ring 2
  13. Halfords? B&Q? Wickes? Screwfix? Car spares outlet? Engineering supplies merchant? Bike shop? Take the short one with you to compare
  14. Blackhat's a country boy as well, but when you ask him about it he gets all sheepish Here are some of his 'Mates'
  15. is This any use Ogri from Here
  16. Are theses any good donny Hereand Here
  17. Thats a good point and the NOS parts for these bikes are very expensive, on the other hand people get pleasure from turning A into B, I think if nothing else you should get that engine sorted and painted up nice and possible paint the tank guards and exhaust, a good job can be done with rattle cans at little expense when it comes to painting.
  18. Unplug the wires from the stand switch, shove an old piece of wire in to the connectors that were plugged on to the switch and try again, this will tell you if the switch is faulty, if it works like this with the switch bypassed then you need a new switch I suppose
  19. Hi Peter, welcome to the YOC forum. Just had a look on the m&p web site Here They do 102 degree plug caps with 70mm drop, they dont mention the resistance though so you will have to check with them but I think 10kOhms is pretty standard. they do two types depending on your plug size so watch out which one you choose. They're only £3.50 each
  20. Airhead replied to Synroto's topic in The Bar
    Hi synroro, ive overcome my shyness, so its a big HELLO from me, welcome to the YOC
  21. plenty ruffians round here to try it out on.
  22. Airhead replied to parkey5's topic in The Bar
    Hi Parkey5 and welcome to the YOC. wow! you sure took the fast track route to an R6. Good advise from shokz there its important to keep the chain clean and well lubed in wet weather and especially salty roads...better still when the roads are wet and salty leave the bike alone and stick with the car, a big ask as they say, especially to a new convert...ride safely and enjoy the R6
  23. Fully synthetic oil is rumoured (has a reputation) as causing clutch slip, personally I would use a semi synthetic oil. I must add though that I have no personal experience of this problem.
  24. Hi Mikey, not seen much of you lately, thought youd bought a car or summat so youll pop in now and again until June eh? Shokz has a Honda hornet too and he didnt give up on us Enjoy your new bike Mikey, ride safe matey and dont forget where we are eh.
  25. Airhead replied to wayno's topic in Yamabyss
    What overflow? if you mean one of the carbs give the one in question a tap with the butt of a hammer shaft just in case the float has somehow stuck. On another note, hasnt this bike got a vacuum operated fuel tap? if so this isnt doing its job because thare should be no flow with the engine stopped
