Airhead
  1. Airhead replied to piston bloke's topic in The Bar
    were both clutching at the same straw you mean...
  2. Airhead replied to piston bloke's topic in The Bar
    Hi, make sure that the tap isnt left in 'Prime' position, also you carb fload needle on one of the carbs must be passing which allows this over filling to occur. if the tap is not in Prime position it is leaking, you can confirm this by removing the fuel feed pipe to the carbs.
  3. Oh thats a real bummer mate But how come you were "(flat out down the duel carriageway)" you have just done a rebuild and didnt you put new rings in or have I got that wrong? Have you ever checked your oil pump and after the re build did you bleed it and force it to full stroke to expel any air in the system? I have never heard of the weak spark theory you mention, so cant really comment right or wrong! As for checking the coil, use an ohm meter, the primary winding is checked from the small wire to the metal mounting of the coil, result should be 1.0 ohm +- 15%, the secondary winding is measured from HT lead (without cap) to the metal mounting and result should be 5.9 ohm +-20% ...Paul
  4. A field bike...just do it, I would also cut right through the bushes (lengthways) just once (I dont mean cut them in half) with a hacksaw, you will find them much easier to re fit.
  5. Airhead replied to Ardy's topic in The Bar
    I know you checked the switches but try again with the kill switch disconnected followed by the ignition switch, see if you get a spark then!
  6. Airhead replied to mrbump's topic in Yamaha Workshop
    Hi could be pulling a vacuum in the fuel tank, it me take aroun 10 miles to pull enough vacuum to cause problems, check any vent lines on tank or any vent holes in filler cap. Next time it happens stop the bike and open the filler cap see if you hear any inrush of air and also see if having done this the problem has briefly gone away.
  7. Airhead replied to Ttaskmaster's topic in General
  8. yep will do no harm so long as youre not going for a long ride with flush in, go ahead.
  9. disconnect your fuel pipe from the carb, open the tap and check for a good flow out of the pipe, there is a screen filter in the tap (petcock) bowl and it can get clogged up with debris, this is an easy check and well worth doing on an old bike with unknown history. ...
  10. Change the oil after you fix the running problems because you will be better off draining it when it is warm / hot The manual states 10W30 oil...650cc quantity Personally I would use any motor oil even 10W40 that you may have to hand, these engines arent fussy and its only transmission oil so will be ok
  11. Hi Tom, you would need to buy or borrow a compression tester, basically its a pressure gauge that you screw into the spark plug hole, then you use the kickstart several times while holding the throttle open, the gauge will show how much compression your engine has and is a valuable source of information with regard to piston ring / bore wear etc.
  12. Darren, FYI there is already a facebook group set up, you will see the link in Alexigno's signature area. I take your point though that it would be a good way for Alex to keep us informed, thats a good idea.
  13. All the above are possibilities, but dont forget that 'cynic' mantioned the choke, its going to be a b4strd to start if youre not using it or for some reason its not working, I dont 'know' your bike so try to fatom if the choke is good. also the usual way is to give little or no throttle when trying to start, is this what youre doing?
  14. Drain the fuel and put fresh in, including the fuel in the carb, you dont know if its good or bad fuel and its an easy thing to do, you havent seen any reason why it blew up, no apparent damage to big end, no seizure, no bent valve...who knows what he thinks 'blew up is' !. you said something about if you pressurise the tank its better...is that still so?
  15. Youre lucky, my DT will only run on one
  16. Yes I did ask James to check out the fuel tap in one of the other threads, James I asked for a description of the tap ON OFF PRIME? have you tested the fuel flow to the carb is good?
  17. Exhaust gaskets are the crushable ally type Fork dust seals should also be renewed, to remove the metal caps, I use an electricians type terminal screwdriver with a good sharp edge, tap the cover up at the join line, work your way round evenly, you will soon have a good enough gap to be able to strike it from underneath. It might be an idea to replace the piston rings in the forks too...part mumber 2A6-23157-00 Two off. Dust seal part number is 2A6-23144-00 Two off. One point for concern is the knocking on full rebound, there should be a small spring in each leg to stop this Part number 2A6-23151-00. Gianelli pipes are hard come by now, but you can buy 'Big one' expansion pipes approx £110 new
  18. It would benefit all if you didnt keep opening up new threads, you must have about five on the go now, people who respond may now know what has already been said
  19. Hi phil welcome to the forum, your bike is a DT125MX, the headlight will only work with the engine running, turn the key to position two and then turn the ligh switch on.. I will check on your carb later but it doesnt sound right to me, I think you jet is too big
  20. Airhead replied to Douth's topic in The Bar
    Welcome to the forum Douth
  21. Well you implied that it nearly ran when you blew pressure into the tank So i'm thinking we should investigate the possibility that the carb is not full of fuel as it should be.
  22. tell us about the fuel tap, does it have ON, OFF, PRIME positions? is there two tubes, one for fuel and one for vacuum to the intake manifold?
  23. Your bike is a single cylinder, the 'big end' is the bearing between the connecting rod (con rod) and the crank pin. take the con rod in your fingers and feel for any up and down or roughness as you swivel the con rod on the crank pin.. you should be able to select neutral gear and start the crank rotating by taking the little end in your fingers and using up 'down movements to rotate the crank (i think)
  24. Airhead replied to wild foamy's topic in General
    Ev'nin Steve, no idea about tyres, those you found look cheap though, t'internet will be your best friend (Google) but I expect you already tried that. Glad the bikes starting well now, did you sort the charging issue, dont recall you saying? How come youre out of work now?
  25. Airhead replied to fazerider's topic in The Bar
    Hi Martin, welcome to the forum. Bad luck with the diesel spills but glad to see it didnt dampen your enthusiasm. Take care out there
