		MOTH$RFUC%EK
		(Moderator mode ON) Wind your neck in newby.
- MOTH$RFUC%EK
		yamaha yb100 electrical problems
		I think you mean Rectifier...
		new member
		Hi Harry and welcome to the forum.
		New Exhaust
		Hi Andy, have you tried Wemoto? ...Paul
- New in Town
		xvs 125 dragstar cold engine problem (??)
		YB100 Electrical problem
		its not very scientific but you could seal the plug hole with your thumb, you should be unable to stop the gas escaping, better still borrow a gauge, where are you? BTW do the test with open throttle
		I would fit the new conenser and do a compression test as the next steps
		Spray panels
		wet sand the black you have done until smooth, then spray with clear laquer use the fuel resistant type. then leave that to cure for a couple of weeks, then T - Cut them using a damp rag and small circular actions for a good result.
		dt125re please help coil clicking
		This is why its best not to open multiple threads about the same problem, all fixed now...Here
		Sounds like clutch drag due to your oil being cold, as the motor warms up the oil becomes thinner and you have less drag, try revving the bike a little with the clutch pulled, then let the revs die off again and select your gear.
		carb problem - advice needed
		a vacuum tap will have two pipes on it (for your single cylinder bike), One is the fuel feed to the carb and the other is a vacuum line and this connects somewhere on the carb manifold. As the engine is running there will be a vacuum developed in the manifold, this vacuum is used to open the fuel tap by operating on a diaphragm within the tap, therefore unlike the basic old tap you dont have to switch the tap to Off position when not using the bike. so if your tap has a line to the manifold its a vacuum tap...if it is I cannot say if it can be stripped as I havent done one, but if ther are screws to undo, then why not drain the tank and have a go, be slow and careful there may be a spring or other bits and pieces in there that you wouldnt want to lose! If you are really frightened of tackling the carb, you could have a word with mervin, he may strip, set the float height and ultrasonic clean your carb for a nominal fee...
		SR500 no go
		With the choke on if cold or the fast idle button pressed if hot, you pull in the valve lifter and depress the kickstart until a little white mark appears in a sight window located on the end of the camshaft. When the mark appears and the valve lifter released with the ignition on give the beast a swift kick...voilla!.....
		1975 DT 175 Headlight not working - Please Help
		Ernie, its a used regulator, maybe its no good! I have described how to check it...
		Let me down :(
		Dont worry about it, just give it a spray with WD40, the leads arent usually replaceable any how, they are an integral part of the ignition coil.
		is the tap a vacuum operated one? if so maybe theres some foreign body got under the seating...this coupled to a float needle valve thats passing = overflow...
		1973 250 MX
		Hi MAS, check the kill switch isnt on, if thats ok try a new plug, if that fails to spark disconnect the black / white from the Ignition coil and with a multimeter check that it isnt down to earth there. ...Paul
		Let me down :(
		???? Because Yamaha only had to make a bike that would do 30mph tops, thats just not fast enough for a young lad with blood in his veins...
		update to my nightmare
		Hi Brandon, maybe the headlight and tail light's are in fact running lights and so will be on all the time the bike is ridden! Just a thought...It's not uncommon.
		Here we go again....
		you cant do the big end yourself, its a specialist job and needs pressing equipment and fine measuring equipment, there are firms out there that will check and rebuild cranks, look in CMM magazine...
- How do
		SR500 no go
		Sometimes its worth a squirt of oil through the spark plug hole, this aids compression on a bike that has been standing...
		few pickies from Stafford show
		Just a few more pics of the bikes there.
		STAFFORD SHOW
		I went in the end, rode down with drewpy and the others from part way, there was loads of the usual old relics there but one was missing...
_33963e.png)
    _83bc35.png)
    .jpg.6e6eb167e0a6dff4733f27bedaf16390.thumb.jpg.c2d8f053e6a294f4d70a79bd2bdaa623.jpg)
