can i change the amperage of a fuse (urgent)
Dan, youre getting confusing now, are you blowing fuse @11 amps with hazaard warning (4 indicators) + rear light on? I thought you were blowing fuse with direction indicator on
Eats shoots and leaves
Awww couldnt u just kiss them
whats 11 amp? just the indicators without the rear light? if the rear light is connected the lions share of current is going there so 10w bulbs wont make it half
yzf750r,, what you think???
Bikes looking good, a stubby would make it better I think too...
Missing Yamaha xt350...
ok mate, have pinned it for a while, hope you soon get it back.
like cynic says, two indicators at 21watts will take around 3.5 Amps so back light and indicator relay have 6.5 Amps for them, to blow straight away does suggest something is shorted, time to get the multimeter out, by the way have you tried the indicators left and right?
STOLEN: Yamaha 600 Thundercat
Topic pinned for a while.
1980 DT 250 Carb problem
No its the other way round, bending the tang down will shut off fuel later and so raise the level in the bowl. set the float level to the specified level, ensure the little spring loaded pin is not compressed as this measurement is taken. If you have the level correctly set and the valve is shutting off properly then the only other way the fuel can seep into the carb is through the sealing gasket for the needle valve (item 6 on the diagram), did you fit this gasket...is it intact?? ...Paul
DT400 Wiring help!
You posted this once, dont be so impatient and double post!
HELP!!! 1978 Yamaha DT 400
You need to look at the wiring diagram and check the CDI is connected The ignition coil is connected The kill switch is connected and is has no continuity to chassis in the off position you wont need the key switch connected. All of the above doent mean the bike will spark though, could be something is faulty.
- New toy..
XT PARTS.
Nick, there is a wanted forum, please dont post wants elsewhere, we turn a blind eye to manuals,,,sorry ...Paul
Following your PM I sent a diagram. ...Paul
Thundercat bar risers
M&P do a big range of bar risers, give them a call on 0844 815 6571 Have a look Here ...Paul
Introducing myself
Hi langers and welcome to the forum. After such an extended storage time you will have lots to check and remedy Have a look at the battery, it is very likely to be sulphated and no use any longer. replace it and check for corrosion of the terminals and battery compartment. Remove the carb if it has one strip and clean it thoroughly using carb cleaner (keep this away from rubber components) and compressed air. Drain the fuel tank and check operation of the fuel tap (petcock) Place bike on centre stand and inspect tyres for hardness, cracks and flat spots, pump them up to specifications. Rotate rear wheel and check chain for kinks/tight links lube if ok. Walk with the bike and test the brakes are working When you have a good battery, check the operation of lights and horn check oil level before running the engine, when engine has run to hot replace oil and any filter if fitted ...Paul
Info please dt125 vs dt175
Oh no youre not matey...
XVS650 IDLE Trouble
may be a split carb diaphragm? ...Paul
- New toy..
1980 DT175 Carb Issues?
The answer is no, all that about removing the throttle slide, needle and throttle sprin has no relevance to adjusting the float height...you just have to do all that to be able to remove the carb from the bike. The float needle valve has a spring loaded pin in the end of it. The correct float height is 21mm so 20mm as you quoted will give a high level anyhow...though not enough to overflow.
Hi Tone (Tony?) the spigot you show is the overflow, put a pipe on it and run the open end down between the back of the engine and the swing arm pivot. Two things 1, sounds like your float needle valve is passing fuel as your carb is overflowing, the float height adjustment should be done with the little spring loaded pin uncompressed, if you did it this way then remove and inspect for a worn ring around the pointed tip of the valve. 2. do not run the bike without a filter as it will no doubt run very lean unless you jet to compensate, this will overheat the engine and may hole pistons or seize whilst being ridden, a start and the odd rev up not ridden will be ok until you fit the filter. ...Paul
Widow- Maker
Well its been nice knowin you john...am i in the will?
GGGGGGGGGGGRRRRRRRRRRRRRRRRRR AAAAAAAAAAAAAARRRGH!!!!!!
Hmmm well i'll think about it Oh...OK, go on then The old nail has since departed and its replacement is on its way...
chugga chugga bike noise
- Hello All
Happy birthday regards JimR
All the best Jim, soon be over the hill like me then...
