dt175 front end
Ok just look into the pin thing then, like i say you may have to drop the forks through the yoke a bit, if you do this you may even find you can still use the 175 brake cable!
dt175 front end
When you say "250 front end" you mean forks and wheel? because the 175 wheel is not likely to be the same or at least you will have to investigate this as well as the steering head pin.
dt175 front end
Greetings. The 250 would be a chunkier front fork i expect but thats not to say it wouldnt do. The crucial thing though is the length and size of the steering head pin, you will have to get the dimensions of both and work it out. Dont worry if the 250 fork is longer as you can raise the stanchion through the yokes by that amount to preserve the geometry of the original fork. are we talking field bike here or road legal bike?
siezing brakes
Salt has a nasty habit of fusing the pads to the disk, no way round it other than dont ride. I suggest you wipe dry the disks after each ride.
Yamaha YZF-R125 Damaged :(
Hard luck Alex and at least you werent hurt or caused damage to someones car. I wouldnt worry too much about fixing up the cosmetic side of things just sort out the brake lever etc to make the bike safe. By all means source and gather the parts but dont bother putting them on yet until May when theres little chance of it happening again. I remember years ago the ride to work 13 miles in snowy icy weather, i was dead relieved to get there....until i fell of at the factory gates, much to the amusement of the security guatds
Gas Tank Rust Cleaning
Part fill the tank with either......... clean m6 nuts Aquarium gravel Broken glass from a car windscreen (go to your local wreckers yard for this) Then fe fit the cap and give it a good shaking it might be an idea to cut a disc out of some thin plastic (kitchen packaging) just to protect the underside of your plastic gas cap
dt175 piston
Cheap pattern parts available from Wemoto Here Linky or Yambits Here Better quality yamaha parts from your local yamaha agent Quality one not yamaha Pro-x Here
VIN number 2001 WR426.
MTC Frame No PNC Model name Model year Country Colour 5NG2 CJ02W 0002470 010 WR426F 2001 FRA DPBSE ...Paul
Pls. help re: Yamaha YZ80k carb install ...
Not familiar with the bike or its carb but it may be leaking from the overlow its a bit of a guess really without a better description or a picture but the overflow is the lowest tube and is connected to the bottom of the float bowl and is facing rearward. The other connection (apart from the fuel feed) is the air vent tube and is connected somewhere on the side of the carb. If it is leaking from the overflow then you will need to check the condition of the shut off valve and the float height setting (which i dont know) for this bike. Merry xmas ...Paul
happy xmas all
Yep Merry Xmas kawasakinit and all members of YOC and visitors to the forums
- Ebay
Ebay
No sooner had I decided I need a rack for the little DT than theres one on ebay, a NOS tower rack that must be at least 25 years old and still has the label and fitting instructions. All it needs is a little polish up and will be good as new.i'm well chuffed and a step nearer the aircooled RD rally in 2010 Oh and will make a lovely Xmas pressie from the mrs
- 2 wheels
DT 175 something or other...
Welcome Cameron, Yep looks like a 79 DT175E, over here they were DT175MX, great little bikes, ive had mine from new
noooob from sheffield
The very place Hadfield AKA Royston Vasey, i've lived here a long time now, dont suppose i'll ever leave
Dt175mx.
Yeah please do, what was the donor bike then and what about the battery....I have always believed this to prevent a 12v conversion, wrongly it seems
Aye the snake is a lovely road but take care with it lots have come unstuck there. Actualy i'm just up the road from the Flouch, i'm at the other end of the Woodhead Pass A628.
Japanese Exhaust System Disease
[quote name='pepperami' date='21 December 2009 - 10:36 AM' timestamp='1261391775' no i have never used that company, but those pipes look like just what i`m looking for. i am just very wary about buying from abroad over the internet??. Wemoto have XS400 silencers Linky
Greeting from t'other side of Pennines Matt
- Sorted
- Sorted
typical card from OG to his missus
Not too far off the mark either , merry xmas drewp's.
Dt175mx.
Well done on getting tho old DT going again ..Now C'mon Andy, tell is some detail then. The CDI...did you replace that? and how about the battery, must have been difficult to get a 12v battery in that small space ? and the voltage regulator that has the purpose of keeping the AC voltage to suit the standard 6v bulb...what did you do there?...12v horn now? You sure went to a lot of trouble for that pulser coil
- Hey were back
xs400 wiring rats nest
Why on earth would you want to do that ? Joking apart though...why?
