Airhead
  1. Sounds fair enough to me, DEP exhausts are not cheap and very low mileage too. Tip...Dep exhausts look good when new but not so good when rusty...if it still looks good then keep it that way with very regular cleaning especially at the header end.
  2. At the risk of stating the obvious again..Good move
  3. Good vid Dave, neat bit of grinding too, was that with a dremel of some sort?
  4. Good news and all that extra power has made the clutch slip
  5. Cant you just remove the filter and see down to the slides, even using a mirror or one of those overgrown inspection mirrors (Dentist stylee)
  6. Good for you Steve, take care while you get 'acquainted'. lets see some pics now
  7. Wow what a gadget
  8. Aah! EFI....Extra feckin insurance Far too modern for me
  9. Does the bike have a fuel tap? If you ever run out of fuel you will need to set the tap to PRI (stands for Prime) position for a minute or two before setting it back to ON or RUN or RES
  10. Janie, i dont suppose you have visual of the slides with the airbox open? i know this would mean a tank removed but i'f all else fails and if it were me i would be watching the action of the slides if it were possible to see if any one of them is having a dicky fit (possible diaphragm issue) I know you checked them though so its a stab in the dark and would mean using a remote fuel supply. bloody awkward problems with four cylinder bikes eh?
  11. Janie you have pretty much done everything i can think of here I would guess at the same but how would you know?
  12. Living proof that the C-Nile virus is thriving in Scotland too Run that link by us again blackhat
  13. Thats what i will be doing, remove and tuck away. I know someone from another forum, he has done this as well as gut the exhaust and jet up and his bike goes well from all accounts. What have you done to yours Vez or was it all done before you got it ?
  14. Been out today, the exhaust is back on so i didnt see the PV working. It does the cleaning cycle ok when i switch the ig on. today it performed a lot better but theres still loads left. My exhaust is still number 1 suspect and the next thing to do is 'gut it' and get a new tail pipe, Cynic you are quite right, just want a revvy bike not a sluggish one like it is now, still it was good to be out today just got quoted £250 ish for a mph speedo which i am not prepared to pay, ordered a veypor digital one at around £150
  15. Airhead replied to jebb's topic in Yamaha Workshop
    Paintstripper is often quite a thick solution, even thicker than wallpaper paste, so unfortunately wont flow into the jet orifice and will just sit there doing nowt
  16. Airhead replied to jebb's topic in Yamaha Workshop
    Nail varnish remover is good, poke it with a nylon bristle pulled from a brush. use a magnifying glass unless your eyes are very young
  17. Airhead replied to jebb's topic in Yamaha Workshop
    assuming the air / box and filter are on the bike i would say blocked pilot jet, float height is 21mm though.
  18. Airhead replied to dalr198's topic in The Bar
    Whats all this bike paint car paint nonsense? Its the colour they are mixing dair PM sent
  19. Two usual causes Warren 1 is the bike fitted with a regulator? check connections to this and that it has a clean earth fixing 2 is the battery fitted, topped up and in good condition? Thats about it ...Paul
  20. Hi Steve not sure about the kill at the moment but the kickstand switch needs to be working. It cuts the engine when the stand is down if the bike is in gear. It stops you riding with the stand dow and coming to grief on the first left hand bend
  21. I've not heard of this pulley thing but have heard of a 180 'flip' of the PV. not sure how to identify if this is needed with mine though. Let me now what you find out Other things to check are the 'snorkel' from the airbox under the seat. The speed limiter in the speedo (reed switch i think) Gutting or replacing the exhaust pipe The silencer
  22. Just the bevelled one in the 125, the other straight one came from my 175. I doubt your 125 has this restriction because no one would put up with that for more than two weeks
  23. Airhead replied to root's topic in Yamabyss
    I sawed off curved section from a steel handlebar off a pushbike and made an exhaust header for my first bike, my mobylette...the brillo was also pressed into service here Happy days and a can of dulux
  24. This thread is a chronicle of the things I did to de-restrict my fully restricted DT125R, If you are on 'L' plates this is something you can do after you pass your full bike test and not before. Well stage one has been sorted, I took off the exhaust and found one of those tube within a tube things in there so out came the dremel again, heres some before and afters, the last pic shows just how severe this thing is compared to the one i found in my DT175MX Comparison with the restriction i removed from my DT175MX
