1974 DT175a (I think) with high voltage from engine
Now youve got me wondering, there is no heat produced by a rectifier unless it is being used as a current shunt to ground, thereby acting as a regulator (a zenor diode) so is this the regulator then?
That is without question a doide then, and furthermore a fully functioning one. I wonder about this resistor, i'm beginning to doubt it exists. That diode is in your case a rectifier, is there another more familiar one on that bike or is this the bike's rectifier? this topic is bearing a lot of similarity to the other one on here at the moment(DT360)
166k is not going to reduce any voltage at all youre right. Acts as a diode though...lets prove that theory, hook it up in series with a light bulb across the battery terminals, then reverse it. if it is a diode and is working the bulb will light one way only,
Hey thanks for the pic, i've been wondering what these look like. can you give me a more detailed description of where this resistor was connected to, I assume one side was to chassis or negative wire. And the other? Measure the resistance of it to see what it comes out at...let us know.
setting TDC on dt100
The bulb may not work as its a flymag ignition. Have a look around the circumference of the flywheel, you just might see 3 lines scribed on it. Now take the plug out and stick a pencil down to the piston. turn the flywheel to find TDC, then back off (clockwise i think) the flwheel around 1.5 - 2.0mm. Now IF you did find the marks I said...at this point you will see a mark on the crankcase to align the middle scribed line to...this is the point at which the contact breaker should open. Some people use cigarette papers to do this, trap one in the points and turn the flywheel until the paper is released, adjust this to co-incide with the alignment of the marks........i'm rambling ...Paul
Help, RT1 360 Has 16 volts to Head light ?
I didnt think these bikes actually had a regulator...only a rectifier. in fact the regulation is so basic that excess voltage is sunk by the battery, if tou have a bad battery...or disconnect ther battery on these bikes you get the same problem. Cosequently batteries and electrolyte levels need to be well maintained and rectifiers need to be working correctly. Also drawings and circuits were basic for these bikes. http://www.slimduck.com/rt1360_wiring.htm http://www.slimduck.com/rt2360_wiring.htm ...Paul
Yamaha rxs 100 running issues....again!!!!!
Reading between the lines the problem could just be a slow fuel feed to the carb, there may be a gauze in the fuel tap bowl, or one within the fuel tank itself. pull off the pipe from the carb and run fuel into something...you should have a good flow not a drip...IF it is slow look at the gauzes. Tip lots of these old school bikes had a screw on bowl under the tap, DONT use a spanner and risk rounding it off ...soft metal, use a six sided socket to remove this (usually 10mm) and dont forget there may be one in the tank too if the one in the bowl doesnt cure it.
Newbie DT 50-R SM owner :)
haha Bertie, its nice to see you enjoying your little bike so much. welcome to the forum ...Paul
360 RT oil fouled plugs
Runs with choke but not without, sounds like pilot jet blocked or partially blocked, could do with a thorough carb clean and blow out with compressed air to be sure. Clutch plates stuck, may require stripping dowwn but sometimes if you can get the engine running properly and nice and hot then they may free up. Get engine hot, stop engine select a high gear, pull in clutch and push the motorcycle along. worth a try before pulling the clutch cover off. A transmission oil change is also highly recommended.
50mph state trooper
Hah...a traffic cop with a sense of humour...must be made up
Yamaha YBR 125 2006 wont start
Try Wemoto
Its time to move on.....
Yeah ...wasnt seriously expecting you'd get another XJR1300...a superb bike. I think 'Gas up - Lets go' has one
You need to get that battery re-charged. Worst case you need a new one i'm sure the bike will be fine after that, choke on, no...or just a touch of throttle £400 for an MOT , thats incredible, think twice about going there again. Now the brake lights popping, that sounds like regulator / rectifier trouble, but sort the battery first and tackle that one next if so.
dt125 overfuelling(?) problem
What can i say...for that price its probably worth it for the needle valve and bowl gasket alone. I bought a kit once and a word of warning, take it easy with the air mixture screw...the one i bought seemed tight in the thread so i didnt force it,,,or fit it for that matter. paid a lot more than that too.
my baby yamaha aerox100
Kishan...Wilkinsons stores...BBQ paint made by Plasti-kote, get it painted, it will transform you bike looks.
Dont forget the circular gasket for under the valve seat
Hey kev...a DT125R, not had so much fun in ages mate and i can only just touch the floor
dt 125
Does the engine just cut out, Or does the bike lurch forward and the engine stalls ?
Foam in gearbox oil and coming from engine breather pipe on DT125R
- Hi Guys - New Member
Welcome sky, great looking bike you have there It will take some time to wear the gloves in as had been said, to make that time go faster just ride the bike more, they say time flies when your'e enjoying yerself- orange warning light
Yep a hello might have been nice but to get back on topic...Who has an owners manual to help bar out ?- orange warning light
Anything in the owners manual? Errr hello BTW- dt125 overfuelling(?) problem
I have a workshop manual for a DT125LC, I dont know whether you have but I can tell you the numbers and sizes of the jets if you want...If you do want this info then the first thing i need to know is the carb id number...something like 34X00- dt125 overfuelling(?) problem
a bent needle will not damage the main jet but could possibly damage the needle jet, there are numbers and letters stamped on them, you may need a magnifying glass to read them. Compare these numbers to the numbers in the workshop manual if you can, and you will need to quote these numbers when trying to source new parts.- De Restricting my DT125R
I cant remember for sure Andy. i bought it along with the boyesen reeds and a main jet and all i was given was a crappy credit card receipt, But i think it was around £85 anyway ring Manchester Xtreme for a price, thats where I bought mine. - Hi Guys - New Member
