97 Yamaha RT100 Bogging Issue
Sounds like crank seals to me, does the transmission oil smell of fuel?
- Happy Star Wars day !
MOT Failed (Shcker - any help?)
Hi mits, thought you had sold it I wouldnt pay that much either WTF is P reg?, a year would have been better but http://www.wemoto.com/bikes/Yamaha/XVS_650_A_Drag_star_Classic/98-07/picture/Monoshock_-_Hagon/ http://www.wemoto.com/bikes/Yamaha/XVS_650_Drag_star/97-04/picture/Monoshock_-_Hagon/
xT125 first bike.. help me lol
Drain the float bowl on the carb, there may be some crud or water in there. You may see a drain screw somewhere at the bottom of the bowl.
Newbie biker ...
Welcome Myami, great little all rounder is the YBR
30mm carb on dt125r
How will you get the jetting right? get it wrong and you could be looking at expense and damage.
sr125 top end rebuild
- 30mm carb on dt125r
No idea but keep us informed eh Will it fit, is it the same physical size? Whats is a pwk?- Is there a specific owners forum for Yamaha IT enduros?
- newbie question - Dragstar 01 125 - rear wheel locking
is it a drum brake, has the cam seized in the backplate (a common occurance) Try moving the operating arm by hand, pull it back, now is the wheel free?- vehicle tracking?
I came up with ideas foamy, for some reason you didnt respond- STOLEN YAMAHA DT 125X SM
I hope the steering lock was not the only barrier to prevent theft, frankly theyre pretty useless, at home you need some pretty hefty chains on and alarms are not expensive if its kept outside I suggest you fit one also...Ask 'Vez' about them.- STOLEN YAMAHA DT 125X SM
No shit sherlock! An unusual happy ending, great news- Best Way To Bleed Brakes on a DT125R
Just fitted a goodridge braided fron line to mine. Remove reservoir cap. fit clear plastic tube to bleed nipple and punch a hole into a jam jar cap. Pass the clear tube to the bottom of the jar. top the reservoir up to its upper level. Stand on the left of the bike. Pull the lever 3 times and on the 3rd pull do not release it. Open the bleed nipple with your left hand, you will see dirty fluid come out, maybe air bubbles too., also the lever will continue to move to the handlebar. When the lever stops...close the nipple. Repeat the process but keep a check on the level in the reservoir. ...Paul- De Restricting my DT125R
Well the 3MB and the 3BN heads have both been used on DTR's at some stage. Scrubbed up well, just need a gasket set now, and some time, and a sunny day!- front wheel spacer RS 100 with RSX forks
You know we would help if we could, not many RXS users visit us at the moment I guess. Try BCF forum, seen a few there in the past- Hello, newbie from Derbyshire
See FAQ's for photos- Hello, newbie from Derbyshire
Uugh...somebody sort that out for me- Hello, newbie from Derbyshire
Obviously not a 'Reject' then <object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>- Hello, newbie from Derbyshire
Welcome 'Weeble' from Derbyshire, where abouts ? Tell me...Have you ever fallen down?- Stuck between Yamaha DT 125 Or a Kawasaki KMX
My bike is a 2003 and like I said I was misled into cutting it up, 2003 happens to be quite a late DTR but key to all this is the number stamped in the exhaust so...If its a 3MB-14610 on your bike Dont cut it open Thats useful info Wish i'd have had the benefit of it You can add to this useful info if you tell us the number on the pipe with the half moons in it- Stuck between Yamaha DT 125 Or a Kawasaki KMX
Good reply 'satelliteone' but I must challenge you on the term "gutted original pipe" You bike like mine is pre DTRE and so there is nothing to gut in the pipe, it is precisely reading this sort of comment that made me cut open my pipe for nothing, as you can imagine i wasnt pleased.It was me that was gutted not the pipe. However there was a restrictor tube in the neck of the pipe, but removing that can hardly be classed as 'gutted'- Yamaha DT 125 R Revs Help.
How do you know? maybe it ran to 9000 when your mate had it. I thought it was running fine before you bought it! but it was in bits Already confused by what you are not telling us. Can you 'come clean' ...Paul- Fuel leak xj600 div
Are you careful to not spill any around the filler with the fuel pump nozzle? There should be a pipe on that that exits the bike lower down where it wont be an issue- Yamaha DT 125 R Revs Help.
Yep, when using forums it is good etiquette to say a little bit obout youself in your first post before 'picking the brain' of fellow forum users. it is also a good idea to watch the forum names, and decide for example where a DTR should be, cruisers, sportbikes, duel sport, workshop etc etc etc welcome to the forum - 30mm carb on dt125r
