Oldtimers grumpy old gits musical quiz.
I knew The Sweet and Blue Mink
DT 125 LC clutch problem 2015
try spraying something like WD40 at the left crank seal when the bike is running, you'll have to take aim through the slots in the flywheel, if it has a significant effect on the running then the LH crank seal needs replacing
finally! my baby drag is running
Great news well done
- Evening all
- ello :)
take off the fuel feed pipe from the carb and then turn on the tap (petcock)...confirm there is a good strong flow of fuel
Chassis paint removal made easy
get some synstrip, that works
Great stuff thanks for the update jeff
1983 MX100 cutting out- video
I don't think it runs long enough to be an exhaust issue, I stick with carb and fuel delivery to the carb myself
hello good day to you all
Greetings Michael
Yamaha DTR 125 RPM Problem (Help Please)
some other problem then, got another CDI to try?
when you turn on the key and the PV comes to rest after the cleaning cycle, the 'U' shaped cutout in the pulley should be directly inline with the blind 4mm hole in the cylinder head...use the cable adjusters to achieve this. That's how the check the alignment
you can easily check the adjustment do you know how to check the adjustment? by the way it's absolutely essential you leave enough slack in the cable so as to not stress the servo motor, it's easy to over tension these cables
is the PV working or has it Jammed up? can you see the thing do its cleaning cycle when you turn the key on, you can hear it too zzzt zzzt ??
Another one for the collection.
as far as I know cosmetically they are both the same...don't know how they were or wernt restricted...i'm not an expert on them though I have a Haynes book
12w was restricted to 12bhp, 10V wasn't restricted
- Another one for the collection.
Engine respray hampshire/Surrey ?
lol, would I be right in thinking there isn't a mrs norm?
Greetings norm is this something you couldn't do yourself?
Dt bogging
Have a read of other DTR threads Heres one
Cyclists
so what might be your opinion of the gentlemen region of women in lycra....that OK as well as the blokes for you Kev ???
Centre stand mods.
Has you bike got any on-board storage for the piece of wood...say under the seat?? it really doesn't have to be a very big piece at all, something that will go in your pocket is well big enough
Centre stand mods.
carry a small piece of wood, say 3/4" thick for starters...roll the rear wheel onto said piece of wood...put on stand...retrieve wood...voilla Fine tune with different thickness for your piece of wood
Shed and Buried
lol like real bikers with an entourage of back up vehicles film crew and god knows what else.....the likes of Nick Sanders...theres a real biker adventurer (other real biker adventurers are available)
Hello everyone
he's from Plymouth, I saw a DTR there once Greetings Jordan
