Airhead
  1. The link doesn't work for me! I think I'd be taking off the generator cover and seeing if theres any up/down movement in the rotor? movement here could cause the rotor to bind up on the various coils and heat them up with possible bad consequences?
  2. you just might have to saw it I'm afraid Rick but I once had success by placing a tube around te far side between the frame and a wall, this took the flex out ot of the frame as it was driven out with a hammer and saved me having to destroy the bolt, of course slacken the nut but leave it on so you don't bugger the threaded end
  3. Greetings David
  4. Ace weekend, yeah well done on the venue finnerz it made welcome change from the usual one...spot on
  5. Great stuff Andrew
  6. I've lost my riding mojo so probably won't hold you all up ?
  7. Hope it goes swimmingly Alex
  8. Hats off to you Andrew well done you, how're you feeling today?
  9. Airhead replied to NE0's topic in General
    Hi NEO it's nice to hear you're still alive and enjoying life...welcome back
  10. Greetings Per, that place sounds frantic...you take care
  11. are these forks the leading axle version or the ones where the axle is central to the fork leg?
  12. Cheers Andrew, out on the pop mate
  13. Hi Pete, you do know the engine has to be running for the headlight but not for the pilot light? Ignition key posn 2
  14. Greetings katt
  15. Greetings Shaun, so what's the vin number? anything here? put qt50 in the search box http://www.vmaxforum.dk/documents/Modell_Index_1958_-_2008.pdf
  16. if you cant solve the problem, if it were me I'd be taking it in for a check over at a trusted garage, these things have balancer shafts I'm sure they do so shouldn't be as bad as causing vision problems
  17. should it vibrate this much? is it par for the course or could there be something making it worse...loose engine mounts for example?
  18. Not. Bad funky moped, black box is to get cheaper insurance, it knows how fast you drive and you may even be on a curfew I think?
  19. yeah its great to be back on the bike, 1st time out for me too, just the commute
  20. in Darley Dale
  21. where are we going then?
