Airhead
  1. Airhead replied to friedegg's topic in The Bar
    Cmon Vez name an shame em I only ever left mine on once and that was because a satnav was hiding the idiot light, ...**idiot light**wonder why they called em that Never mind fried egg I once went to the wrong test centre for my test,waited hours before anyone asked me why I was there...I was camping in wales at the time so rode all the way back home to the local centre and the ironic thing is I passed the centre I was booked into near to where I was camping
  2. This could be the problem. How did you do this? All the connectors are factory fitted and not really replaceable. Did you cut them off? and replace withsomething else? how did you attach to the cut wites? OK I am making lots of guesses here because your post lacks detail Oh and I suppose a hello might be appropriate for a first time poster
  3. Backfires can be caused by loose exhaust fitting or rusty / perforated exhausts.
  4. Give upward pressure to the bottom of the bolt whilst simultaneously turning the bolt anti-clockwise.
  5. I asked if you could see light through the pilot jet not the main jet
  6. Sounds like a possible blocked pilot jet, can you see daylight through it?. Other issues to consider with and old stroker are crank seals but sort the carb first.
  7. Try a new spark plug If the bike is elec start then re-charge the battery Fill the fuel tank and drain the float bowl if thats possible if its a vacuum tap on the tank, switch to PRI position for a few minutes.
  8. Nice one Drewpy and congrats on the podium, its a bit ironic the S&S bike has 'wheels of ally' BWJ I wasnt invited, perhaps Drewps thought I would let him down...perhaps he wanted OT to himself
  9. Could be a dirty air filter, thereby richening the mixture.
  10. Ive never had my motor in bits but I expect the clutch will have to come off to get at that as well...ask Vez. If so it may mean special tools to hold it firm while the centre nut is undone...check your haynes book or if you can...enlist some help.
  11. Its in the haynes book page 61. It is fitted at the opposite end of the shaft to the gearchange lever. It will mean an oil drain and clutch cover removal to inspect which in turn will mean a new spring if its broken and new gaskets, I strongly advise a new shaft seal too if you do have to replace the spring.
  12. Have you got the key switch fitted and operational, have you bypassed the stand switch?? have you connected the neutral light? Do you want a working PV if so you will need the battery and fuse fitted. I have no experience of this but Vez has...he has an off road DTR
  13. Hello and welcome Todd
  14. Airhead replied to Ladyboy Rider's topic in The Bar
    Welcome Rick
  15. Welcome toolmaster I have to ask why you did not transfer the loom also? As far as i'm aware DTR's of different ages will not have the same loom so as Vez says joining the dots may be difficult, for example the cdi may be mounted in a different place on the two bikes and have different pluc connectors. ...Paul
  16. Thats what comes of asking tech questions in 'The Bar' Topic closed as you raised it twice.
  17. Are you saying the lever does not return to centre when lifted up or pushed down? If so it could be a broken torsion spring, see item 3 %201A3RM-300EA/SHIFT%20SHAFT/"]shift shaft
  18. Airhead commented on Stevee's gallery image in Members Rides
  19. Happy birthday Auld-een and yamahead
  20. you need to examine the float valve. see if there is a noticeable ring worn around the poited end, or if there is a flake of rust or something stopping it from closing, take care there is a fragile gasket under the brass seat, see that it is fitted and intact. if in doubt you need a new one.
  21. The 175, although I hope to have it ready 9th, 10th, 11th July
  22. Airhead replied to kxm97275's topic in The Bar
    I dunno can you compare part numbers somehow?
  23. Went last year, not sure about this though I was planning going on the ACRD rally, Only thing is my bike is in bits and not MOT'd
  24. Airhead replied to Stev125's topic in The Bar
    Not heard of that one, i'll look out for it. My favourite is French connection merlot.
