Dt175 fine tuning
doesnt make sense does it so thats why I think it may have something to do with the pilot jet/air jet stuff, your bike is standard with a 160 so it should be happy with a 170 with the Gianelli. Looks like you have been trying to solve a carb issue with jet and needle changes when the issue is something other than jet or needle position. Also have you checked you have the right needle in it. If you cant sort it why not try your spare 3u500 carb I cleaned it up before sending it back to you
Dt175 fine tuning
why would going from a 160 to a 170 mean it wont run at all, thats not right. It should run with no main jet at all fitted shouldnt it? of course it would be drowned out at WOT without a mj but it shoud still run ok at up to around 3/4 throttle. Would it be worth checking your air jet isnt blocked.
Pictures too big
yes you can but its tedious and slow, so I do it before uploading.
C"boardDave Will travel
God its freezing, has he got heated grips, thermals, a hip flask...or is he just mad
Dt175 fine tuning
What makes you thing it goes from rich to lean Jason, I doubt that and would think it goes from rich to richer. If it was going lean at large throttle openings the only evidence you would have is a plug chop...I doubt you would know from performance until it holed a piston. But you would certainly notice poor performance by being rich. I have a gianelli on mine at the moment and it seems ok with a 140 instead of 130 (early airbox taken into consideration)
- Pictures too big
another xmas gift for drewps
"Its ok dear...I'll do the shopping from now on"
I know what a pulse is and for that matter a jet too, but whats a 'pulse jet' whats it for?
Long time no hear/see
Good to hear from you again EmZee, specially good as you got the bike running and legal. Thanks for the update
Price This Lil Gem please
Aaah so barky was right , so congratulations Pat and mrs Pat, you kept that quiet
Hey barky it was for his brother wasnt it?....Psst do you think he had designs on it anyway, about that gonad-gel technological seat
Yeah thats a nice looking bike,...There will be others
Pat can you find it on your browser history?
Intro and 1st Yama Project - 1981 XS400SH
Good intro Jack and welcome
I have no idea Pat but I would be very happy with it for £1300 even more, sounds mint
speedo not working
- speedo not working
sorry wullie I dont, ask redrose- 88 fz600 HYas spark but then loses spark
no you cant just swap the plug (HT) wires, I meant swap them both entirely..ie substitute one for the other.however if it is not always the same pair of cylinders it may be something else.- 88 fz600 HYas spark but then loses spark
could be a broken wire or connection too, try wiggling the wires around near the generator, keyswitch and at various places around the loom that may be relevant- 88 fz600 HYas spark but then loses spark
How about you swap the two coils for each other, then see if the problem appears on the other 2 cylinders, this will point confirm if it's the coil.- speedo not working
If you pull out the cable from the speedo does it turn as you spin the wheel? and also if you grasp it between your fingers you should not be able to prevent it from spinning as the wheel turns. Speedos are not meant to be messed with- 12v switches
ok but if you get ripped off dont blame us.- loseing power in higher gears
but you said the valve works? so the motor is fine and still connected then- 12v switches
Yeah sure Paul try These Guys- This looks painful.
I prefer funny vids myself - speedo not working
