Airhead
  1. Only time I would do that is if I had run out of the proper stuff Jim. It doesnt stick anywhere near as good as chain lube ( I use the wet sticky type), and not that I do much these days but riding in the wet would soon see it off.
  2. Greetings Ryan the geordie
  3. Greetings spongebob
  4. Greeting Jordan
  5. Dont put a new chain on your old sprockets Jordan, it will wear out double quick.
  6. no wonder it stripped gears totally different thread pitch add shims to reduce pump stroke yes but I think it is not possible on later style pumps, ie the ones with a push on cover over the bleed instead of a screw plug. not 100% on that but I think I read it somewhere between Haynes pages
  7. maybe it would be worthwhile joining here http://rd125lc.proboards.com/index.cgi?action=search surely they should know, if you do find out though let me know.
  8. Get the mobylette working Drewpy, you'll steal the show mate or you can borrow my DTR
  9. I would fit a new exhaust gasket Paul, you said not long ago your exhaust was cherry red, this could have damaged the gasket and cause an air leak...air leaks cause bangs.
  10. Airhead replied to 2Smoke's topic in Classics
    Nice...who did it...any chance of a picture?
  11. Airhead replied to 2Smoke's topic in Classics
    how is that possible?
  12. me too I love the strokers events
  13. Airhead replied to 2Smoke's topic in Classics
    Pete is right, you need to adjust the preload, remove the locking screw and turn the collar. Jack up kit is precicely that...it will give more ground clearance and done front and back could be desireable off road, it will however still bottom out unless you lose some weight or adjust preload or both
  14. lol youve no chance now, you should have said its only 3 mins and hoped we didnt notice...and speaker building !! I see though you decided to 'spare' us by not posting the video or a link
  15. Uunless you can think of something youre going to have to space then 5 notches apart and be done with it.
  16. Yeah I came to the same conclusion, it still wuoldnt have worked if it was biased. I am dumbfounded by this, 23 slots is 15.65 degrees between each slot...so how come Haynes can make approx 70 degrees from that. And for that matter why didnt they say 72 degrees which would have been correct (but still unachievable)
  17. Thats woth investigating, isnt there a punch mark and an arrow to align?
  18. Funny thing is my DT175 has ten slots for the friction plates and so it is easy to arrang the 5 plain plates evenly, yours has only 8 slots
  19. are all the plain plates identical though, thats a straw worth grasping at although I cant imagine why any company would incur higher production costs to make them different
  20. Now by my reckoning if the clutch inner drum had 25 slots then 5 slots would be the magic 72 degrees, so what's going on there then.
  21. Yeah I see what you mean, no matter what you cannot make a true 72 degree spacing with just 23 slots, Now it's bugging me too or are we missing something
  22. Do I hear the PAT..ter of tiny feet
  23. Not trying to put you off, just saying be careful and you wont go too far wrong. Try an artist paintbrush and some white spirit, operate the switch a few times and blow it dry.
  24. dont go too deep kishan something may spring out and be lost if youre not careful, try to clean the contact faces if you can see them
