Airhead
  1. I make it XS500F 1978 Austin.
  2. Greetings Dan The R1 is far too powerful for umm...a 19 year old so stick with the R6,
  3. Good advice Tony, some nuts can be torqued but the DTR gives too little clearance for sockets on some cyl head nuts, so a little guesswork with a ring spanner has to be applied. DTRs are renowned for blowing gaskets and so I will say again a thin line of silicone around the bore circumference (just 7mm wide) is of benefit and it cleans off quite easily,
  4. Airhead replied to DTGordo's topic in Classics
    I cant understand how it was dry unless the oil level was extremely low?
  5. Greetings matt Hairspray...well I suppose it's appropriate for a aerox hairdryer
  6. Greetings Florida Joe
  7. Either the air filter is dirty...or you are using the choke?
  8. Even a cheap one may work with the film of silicone as I said...I fitted it dry
  9. I have used a cheap one once and sure enough it failed. I use proper ones now and run a thin film of silicone manifold sealant around where the bore is only about 7mm wide not the whole gasket (you have to get it off again sometime) do this both top and bottom. Your head may be warped though I cant comment on that but skimming should be done proffessionally in my opinion. At a guess place the head on a piece of glass and ensure it doesn't rock in any way.
  10. are you using a cheap after market all metal gasket or a pukka yamaha rubber coated one?
  11. Airhead replied to a post in a topic in General
    I,m having similar problems with my bandit, looks like i'm hading for a carb strip as two cylinders are not getting hot at the headers and thay are not common to one HT coil
  12. Greetings Nacho
  13. Greetings Terry from Staffs
  14. Greetings Ian theres no way on this earth that a virago 125 puts out 33 bhp
  15. Greetings tone, have you tried councelling?
  16. Greetings Bernies son
  17. Greetings raxxla
  18. 125's have one less friction plate, and generally look different
  19. Greetings Mark TDR 125...what an awesome little bike they are you lucky g1t
  20. Not sure on the switch issue but there are two versions of CDI, one is 6 wire and one is 7 wire, the presence or absence of a RED is the difference, early bikes had two source coils in the magneto...the RED connects to source coil 2 on these.
  21. Greetings oneowl plenty of XS400 expertise and interest in here mate.
  22. Greetings Tye Every time I see one of these babys I cant believe they are only tiddlers. Look forward to seeing your progress with this.
  23. Greetings 'Wings' aye we loiks enduros ere
  24. The other two wires Blue and Black are for the meter light so leave them be, you are only concerned with Blu/Red and Blk/whi If they are shorted disconnect them, if they are not shorted then short them. I advise that whatever you do try to do it in such a way as to not damage the wiring, like short them in the plug for exaple rather than chopping your loom.
