CT3 Runs OK, But Maybe I can Fix That!
I really cant see what all the dufficulty is myself so long as you have a: The top ring is keystone b: The pin clearance cutouts the right way up c: There is ONLY ONE expander ring to fit...in the bottom (parallel groove) Possibly you will find it easier to fit the piston into the bore away from your bike?? Place wrist pin in the deep freexer for an hour or so Place rags in the crankcase Fit just one wrist pin clip into the piston Fit the top of the piston / rings into the bottom of the bore If you have a hot air gun or blow torch warm up the bottom of the piston (or even place whole lot in the oven for 15 mins) Retrieve the pin from the freezer and quickly assemble to the con-rod job done It is a concern you said spreader rings (plural) Definitely only the one in the bottom, you will notice the bottom parallel ring is narrower...to accomodate the spreader ring behind it
where to find VIN number?
yeah my DT175 are the same, its the later bikes and i think ALL later bikes that are different, dont know when it changed tho
shotblasting does ruin the numbers, it did on my DT175, barely readable now after several re-coats Have a good look with a magnifying glass and compare it to your V5C
Has it been powder coated Dean? NEV my engine / frame #,s are different. I think that this happened somewhere along the line for some reason
Mines on the headstock Dean (2003) Most bikes are in my experience. Ask NEV his is an older model isnt it?
My DT175mx
Thats possible sure shes a lovely example...hope you get to keep it mate
My DT175mx
Not sure mate you never can tell, I assume you have been watching them go yourself. If I were to guess I would say anything over £1000
My DT175mx
Not looking too bad to start with there (not easy to tell though) see you got a genuine exhaust, a wheel rebuild??? done much to her?
My DT175mx
One of the first Clive, she looks spot on...Got any before shots?
power valve trouble
did you leave some (just a little) slack in the cables? I would take out the PV and clean it up with a rag and white spirit, could be gunged up? Try disconnecting the cables and see if it feels locked up
07 DT125X Splutters
Thats your problem then, it needs a seal...It will perform better with one as well. Take some measurements perhaps this is it ? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300558072498&ssPageName=ADME:B:WNASIF:GB:1123
07 DT125X Splutters
on the DTR there is a rubber connector joining the exhaust / silencer, is yours the same? and if so check it for splits / damage
Aerox cold starting problem.
yeah me too, or the float valve dirty / worn
dtr won't start
you will have to get the water out. I have never done it nor seen it done...perhaps google it? im thinking a syringe with some tubing attached...fish tank air pump type tubing...that would be about the right size. Get it all out every last drop then give it a good spray with WD40. Then maybe leave it for a day...maybe not before rebuilding.
New here
Greetings chris dont see many combos around these days...now that cars are so cheap like..
Just saying hello!
Greetings printmitch
New Member
Greetings Randy
dtr won't start
Of course it shouldnt jon. when you loosened the head...didnt you drain the coolant first?
- Just saying hi!
Hello from Conradv2
Greetings conrad yeah you need to real sure it's right before 'junior' gets a go...I mean real sure
foamy on horse trancs
fck me pass me the paracetamol
- Hi
hello all
Greetings mzman they arent heavy once you get em rolling though eh?
mr newbie
Greetings stonesey
Hello from a new member
Greetings Jo
