Airhead
  1. more likely to just stay on i would think
  2. Greetings Jack..whats up
  3. great bike denny
  4. Alex peoples signatures and avatars have gone..probably much more too, and the post count is up the chuff also
  5. yeah i feel for you Dean it's crap. I take there is a time frame and you are within it?
  6. might be worth asking the seller here http://www.ebay.co.uk/itm/Yamaha-RXS100-L-H-engine-cover-/260582745229?pt=UK_Motorcycle_Parts&hash=item3cabf1248d
  7. yeah it stinks, you will have to shop around...do the online ones and you may find that some ask for driving convictions only...it would be time consuming but may be worth it.
  8. Airhead replied to jebb's topic in Yamaha Workshop
    Hmm i've never seen one of these can you PM me some pictures I would like to see it?
  9. Airhead replied to jebb's topic in Yamaha Workshop
    DEP sound good, are you sure yours doesnt just need re-packing though?...much cheaper than replacing it
  10. I just posted a link to one...ask, the very fact thats it's black suggests ita a rubber COATED one to me as for water pump seal gone, this will give a milky appearance to the gearbox oil so dip it and see
  11. Airhead replied to andyyam750's topic in Projects
    very nice Andy, bet it's a hoot to ride
  12. LOL what a swap
  13. Airhead replied to GSXR988's topic in Classics
    Why not have a go at painting the plastics yourself, blue ones are hard to find...mine's blue so i know.
  14. Airhead replied to Razer100's topic in Projects
    WOW! she's like new
  15. Here is the standard reed and cage I fitted boyessen 2 stage reeds to mine Here is the standard inlet manifold Lots of people are led (wrongly) down the path of chopping off all the rubber moulding that enters the reed cage, myself I just chopped some off and left some on as it is used to direct the fuel air cleanly to the reeds...this is what I did as for main jet...it would be wise to jet 10 points higher, for example from 240 to 250
  16. B40 will be the best, the D5 will be excruciatingly slow
  17. This looks like one, ask the seller http://www.ebay.co.uk/itm/Gasket-Top-Set-Yamaha-DT125R-TDR125-1988-2004-/280474351304?pt=UK_Motorcycle_Parts&hash=item414d92f6c8 Dont forget a 7mm thin smear around just the bore circumference both sides http://www.ebay.co.uk/itm/40G-CLEAR-SILICONE-INSTANT-GASKET-RTV-SEALANT-/140565596435?pt=UK_Body_Shop_Supplies_Paint&hash=item20ba5cc913
  18. Greetings Szwed
  19. so you ran a wire direct from the battery + to the ignition switch? did I interpret this right or have you still got the fuse in line? power to the headlamp is possibly direct from the magneto same as my DT175, the battery feeds the pilot lamp, indicators, tail lamp stop lamp, neutral lamp and dash (clock) lamps and horn.
  20. Airhead replied to clivew1965's topic in Yamaha Workshop
    Theres a quick and easy test for crank seals I wouldnt have trusted the repro carb though Left crankseal would be prone to suck air and run lean and hard to start, right seal would be prone to burn transmission oil and be rough running and smoky
  21. Airhead replied to clivew1965's topic in Yamaha Workshop
    Totally new but a genuine one or re-produced?
  22. Airhead replied to clivew1965's topic in Yamaha Workshop
    Clive it would help if you fill in your profile, It's no use asking if anyone is local and not saying where you are! If it comes to it...I could post you yet another carb to try. or we could take it through the forum and you examine your carb and see if all the components and settings are as they should be. I already posted the details of this earlier
  23. Airhead replied to blackhat250's topic in Yamabyss
    I see the government petions website has crashed and will be re-instated Friday, the target of 100,000 signatures to evict ner-do-wells or their families from council homes if found guilty has been surpassed and so the MP's will have to discuss it (by their own rules). It will be open for more voting Friday guys if you care to add to it.
