Airhead
  1. its often the way that the clutch has to be pulled like we said earlier
  2. sounds like a dodget neutral switch, have you tried moving around the gears then going back to neutral?
  3. Airhead replied to drewpy's topic in Classics
    is that L plate legal sonny
  4. Airhead replied to Hughzy69's topic in General
    Bloody hell...thought you said you tried ebay!!! http://www.ebay.co.uk/itm/YAMAHA-TDM850-CARBS-CARBURETTORS-TDM-850-3VD-92-/280623646326?pt=UK_Motorcycle_Parts&hash=item4156790676
  5. Airhead replied to Hughzy69's topic in General
    after ebay i'm at a loss where to look, not exactly hundreds of TDM's around is there. What happened to your carbs then...did they fall off on a ride
  6. Airhead replied to 18j's topic in New Members Welcome Area
    Greetings 18j great bike how you liking it ?
  7. Heck just make sure it's in neutral first and try pulling in the clutch also
  8. Greetings matt only paid up members can use the wanted forum and generally wanted ads may get deleted if not posted there. keep a watch out on ebay for your tZR tiddler
  9. Airhead replied to 18j's topic in Classics
    befor rushing into buying a new one try connecting the black of your 3 wire relay to ground....it may well work
  10. Airhead replied to 18j's topic in Classics
    some are 2 wire and some are 3 wire...buy the one that equals the number of wires you have. At a guess i would say the cylindrical ones are 3 wire and the square ones 2 wire...thats often the way with DT's which have similar electrics
  11. looks like the previous owner wast so bothered but they make grips specially for custom style bikes http://motorcycle-parts-accessories.co.uk/product/8084/oxford-hot-grips-for-custom-bikes-1-inch-handlebars?utm_source=froogle&utm_medium=organic
  12. Obviously you are not familiar with the boats.net website! and obviously the OP was too rude to respond to the reply he got back in April!
  13. Airhead replied to kearnsy123's topic in The Bar
    so you have a manual but it doesnt tell you what oil to use and where to fill / drain it or even how much to use? what manual is is it?
  14. Airhead replied to Noise's topic in Projects
    but rather than risk a fail because they dont have one you could use one of those often fitted to the rear of bicycles
  15. Airhead replied to Noise's topic in Projects
    yeah that looks very nice...now for the but ! but you will need a reflector to pass the MOT
  16. Airhead replied to kearnsy123's topic in The Bar
    Really kearnsy you should buy a manual and read it rather than have to ask about every little detail. Its a TDR, I never had one but my DTR oil went in a tank at the front behind the radiator scoop. Maybe yours is under the seat...I dunno but be careful not to pour oil in the cooling expansion tank. The gearbox oil fill is obvious although the drain plug isnt
  17. Airhead replied to kearnsy123's topic in The Bar
    dont use the heavy transmission oil kearnsey, your clutch will drag and gear selection will be clunky...neutral selection will be nigh on impossible i would expect. use any motorcycle specific oil for the transmission, personally i use motul transoil but there are many more...have a look at the opie oils site, they are doing an offer at the moment arent they? isnt there a post up about it?
  18. i'll see if theres any left at work next week.
  19. ok PM me your email and i will attempt to send it, if someone else wants it, you send the next one etc etc
  20. I devised an improvement on the tensioner arm, the original setup tends to wear down the arm and spring, flattening the spring and wearing grooves in the arm. the gap between the spring and arm in in my opinion a little excessive so i found a bit of thin wall stainless pipe and cut it to size, a wrap of tape on the arm made it a nice tight fit The finished article and another improvement, a grease nipple to lube the pivot bolt
  21. Yes the original panel decal for 1978 had the D, R, O and 5 all filled in with black. I have an original MCM 'Road Test' from 1978 anyone want me to scan it?...hmmm not bad for £570
  22. Greetings richie
  23. date of liability 1992...thats a long long time ago !
  24. From the DVLA website VEHICLE ENQUIRY Services Provided By DVLA: The enquiry is complete The vehicle details for G131 MAG are: Date of Liability 01 09 1992 Date of First Registration 18 08 1989 Year of Manufacture 1989 Cylinder Capacity (cc) 1188CC CO2 Emissions Not Available Fuel Type Petrol Export Marker Not Applicable Vehicle Status Unlicensed Vehicle Colour BLACK Vehicle Type Approval Vehicle Excise Duty Rate for vehicle 6 Months Rate £40.70 12 Months Rate £74.00
