Airhead
  1. Greetings cmoore nice intro and good luck, you'll get good advice from here
  2. Greetings to another old DT owner a picture would be great
  3. kiln can you give a little more detail we need to know all the facts what is the bike and its year this piston...is it new and has never been used?
  4. what about the other differences phil...the brake plate / spindle etc.Have you tried your brake plate against the new fork...is it ok?
  5. Greetings pair of aces
  6. Airhead replied to drewpy's topic in Classics
    Looking good drewpy...cant wait to see the finished thing then we can start on the ped
  7. I dont think you would get a spark without a battery
  8. as for other differences between the US / European bikes European Speedo bracket 2A6-83519-00 2A6-83570-30 Speedometer assy 1V1-83536-00 Tachometer assy 401-25181-01 Wheel axle 90171-12005 Nut castle 2A6-25120-00-98 Brake shoe plate 1981 DT175H (American) Speedo bracket 3J0-83519-00-00 2N4-83570-A0-00 SPEEDOMETER ASSEMBLY 2X1-83540-F0-00 TACHOMETER ASSEMBLY 353-25381-00-00 AXLE, WHEEL 90171-10004-00 NUT, CASTLE 2N4-25016-01-98 BRAKE SHOE PLT ASSEMBLY It looks like the ignition switch on the US bike does not mount on the meter base so perhaps it mounts directly to the top yoke? of course this also has a different part number. There may be more i havent considered
  9. Phil I will check those numbers for you but first I want to 'bounce' this idea off you. I know you have all the components for a good set of european forks but with cosmetic pitting only between the yokes bu good in the working area, and that you naturally dont want to lash out on Philpotts hard re-chroming just yet at around £150. so then i saw this on another forum, it is actually for a dt175 and i thought you may like to see it shall we call them decorative sleeves
  10. numbers are often on the left side of the engine...how come you cant find it?
  11. blocked pilot jet maybe ? you may find it improves with the choke on?...this would point to a carburation / jet issue.
  12. Airhead replied to 18j's topic in Classics
    just earth it at a convenient chassis point, for example at the ignition coil mounting screw, also check the indicator bulbs are the correct wattage specification.
  13. Thats gorgeous you lucky b!"£$%^d look after her and take care
  14. Try wemoto yambits and Fowlers of Bristol for spares...they all have websites
  15. i make it a 1994 so it's the 'modern' style one...we never got that one here in europe most likely because our learner capacity has been 125cc for many years now.
  16. whats the engine / frame number chris?
  17. Cant help you with that one !
  18. great choice Dan think of the money you'll save and the fun you'll have. Will you be riding in winter?
  19. not when the neutral light isnt on!
  20. yes i checked and it's either on top of the engine where i said or in that vicinity. With a multimeter check it for continuity or if you dont have a multimeter...with ignition on and using a piece of electrical cable touch the connection and at the other end touch to chassis (engine case) this should bring the lamp on...if it does the switch may be faulty...if it doesnt the bulb / connections may be faulty. Light green connects to blue on the switch
  21. Dunno...never had one of those bikes. Try on top of the engine case near the drive sprocket...they usually have just one wire ...may be behind the chain case cover also but i'm just guessing. Have you got a wiring diagram it may help as you could see the wire colour on there?
  22. Greetings benny, great little bike...good luck with the resto
