TZR 50 help please
Greetings kelzi no doubt the bike has a vacuum operated fuel tap, the 2nd pipe (vacuum) will plug onto a spigot somewhere on the engine side of the carb throttle valve (slide), thus when the engine is running...vacuum is created and this in turn opens the fuel flow to the carb. as for the overflowing perhaps the carburettor float valve has jammed, initially try tapping the carb with the wooden stock of a hammer...I said 'tapping'
'76 XS500 Timing
well thats a great help Jim
Want more Power Yamaha Chappy 80cc
Ahh its never going to fly with a guy your size but if you check the ignition timing, keep the exhaust de-carbonised and a clean air filter you wont go far wrong, they are a great little fun bike scooter...enjoy..up yours is just having a laugh and hes showing off because he did lose a lot of weight and thereby made his LC faster
- Yamaha aerox airlock?
78 dt 175 kickstart help
yeah just buy a yamaha one
Hi from the UK
greetings rick, be nice to see it as was and as is
you can test the pump if youre not sure, pull the pipe from the carb or manifold, block off the spigot with something (not bluetac etc) maybe a pice of tape. start the bike and allow it to idle, turn the pump puuey by hand to max a see if the oil pulses out of the pipe, is the oil clean? how about the 'Intro' Dan?
yamaha tdr
theres a sight glass, bike upright and engine cold, halfway is good
yeah keep filling, running, draining etc and eventually the water should be clean, only then drain a last time and fill with de-ionised (distilled) water and anti-freeze solution...winters coming . In the shrt term keep an eye on the level in the radiator when its cold untill you have some confidence in it. Tip, when filling a drained system keep squeezing (pumping) any exposed rubber hoses to expel air and reduce the chances of airlocks
- DT 175 MX problem.
SR125 Wont start, Just clicks
an intro would be good, this is more often than not a discharged battery, re-charge it. if it then works but fails soon after replace it
A n00b and an SR125
greetings Ruby, keep it clean and serviced, look after the chain adjustment and lube and most of all yourself
Dt 175 Mx wont start
thats lucky, might have taken longer without the prior knowlege, incidentally you may know this but disconnecting the ig switch would have given you a spark
SR125 - how hard to change clutch plates?
youll need new oil, a new cover gasket and the plates, try wemoto. you shouldnt have any trouble if you have some know how, Take care with the plain plates they sometimes need to put in...in a certain order around the basket to achieve balance...or vibration will occur, try wemoto for your parts of course you need a little slack in your cable before you delve this deeply
- The Joke page
- blow your neighbours house up
well done NEO
YBR 125 too long warming up
Greetings Roy, is it fuel injected, does it have a manual choke...not familiar
- Just saying howdy
!!!!,,,,,need help finding lighitng coil for yam dt125lc2 c reg !!!!....HELP
please use this forum for intros chippy, let the problems come later
Hallo
Greetings milan, how do you compare the DTR and WR ?
Identifying this MIKUNI carb
where does this info TI/TL32 come from? mr Haynes has it as TM28SS code 3RM02 for 1999 to 2003
ybr 125 Starting Problems
if the problem is pressurisation due to sunlight why not open the filler cap to release it? I know it isnt a cure but it may be a fix if you are in a fix!...better than a wet towel in your pocket lol. come to think of it, perhaps you should be questioning your tank venting capabilities
