Airhead
  1. if your bike runs well there is unlikely to be any issues with the carb, as for the exhaust, dunno but check the header pipe hasnt got a washer or smaller tube in the neck
  2. Airhead replied to littlej's topic in Yamaha Workshop
    great let us know the result and a picture would be good too
  3. looking good drewps
  4. dont be so impatient, £150...yeah buy it if it has a V5
  5. sounds good, and have a spray around the inlet and left crank seal with WD40
  6. yeah sorry clive i'm getting mixed up with another poster, too much going on at the moment m8
  7. Airhead replied to oldtimer's topic in Yamabyss
    Happy birthday Steve
  8. we seem to be going round in circles here? early bike 130, late bike 160 i'm sure you have seen me say this in other posts? not just that though there are all knids of other differences, with the exception of the pilot jet the later carb is richer on all fronts, if your bike has a later airbox then a 3u500 carb should be fitted ok then for the earlier version Mikuni VM24SS, Number 2H500 Standard Set up with factory porting, standard exhaust and air filter Throttle Slide cutaway, 2.0 Needle, 4j13 Clip position 3 from top Needle Jet, 249 0-2 Main Jet, 130 Pilot Jet, 25 Reed side diameter, 35mm Filter side diameter, 43mm Length, 85mm Float Height, 21mm Later version for bike with airbox on left Mikuni VM24SS, Number 3U500 Standard Set up with factory porting, standard exhaust and air filter Throttle Slide cutaway 1.5 Needle, 4j6 Clip position 3 from top Needle Jet, 267 0-8 Main Jet, 160 Pilot Jet, 20 Reed side diameter, 35mm Filter side diameter, 43mm Length, 85mm Float Height, 21mm so you see for example that your 125 carb with its 2.5 slide cutaway is leaner than the early 175 with its 2.0 cutaway, and even further away (leaner still) that the 1.5 cutaway of the later model 175 carb perhaps this is why you have idle issues and also its risky for overheating and seizure if you run too lean as well you know!
  9. Nah you need to stand on tiptoes for maximum dazzle on high beam
  10. more pics plz, maybe a bit further away
  11. manual choke? ok when choke is on but not when off?
  12. Greetings Dave
  13. c c c c c cad
  14. Nice find drewpy, never heard of them
  15. Greetings Trev, yeah the beard pony tail and bandana will be cool
  16. Greetings matt
  17. Greetings Pete Yeah its annoying when you give advice and dont get a response, early days yet though...be patient
  18. Greetings Aaron give my regard to lizzie n Phil
  19. you too Steve
  20. Great intro Dan, so lets see a pic of the 250 YBR and your opinions when you have it
  21. Greetings willgree
  22. Airhead replied to clivew1965's topic in Yamaha Workshop
    She looks very nice Clive, is she new in the stable? Check the reed petals arent curving upward at the ends, they should be seated at the end and a small gap in the middle section. Have you checked the bulb filaments with a multimeter?
  23. Could still be carb issues Clive, with a 2.5 slide cutaway it may well be very lean, theres more to it than just the 160 main jet, keep an eye on ebay you will find a carb before too long, when you do ask the seller if it is id 3U500, thats the one you want.
