Airhead
  1. Ty Trials sell DT175MX keys for about £1.65, I would be surprised if they are any different to the 125 LC key! yambits are a yamaha agent who will mail order, ask about the 10V key...........
  2. too far for me kishan, you going? what on that four stroker skoot
  3. look on their website again and get the phone number fella
  4. give yambits a ring ollie
  5. here you go ian ina http://www.mandp.co.uk/productsList.aspx?style=0&kw=&bike=870-2003
  6. sounds like a blocked main jet and/or power jet an intro would be good in new members...Thanks
  7. I never had anything chromed there but had some poor chrome removed and polished for re-plating, but i saw their work it was absolutely first class...they wont be cheap though. i had a bad experience somewhere else local so thats why I recommend them. Best bet is to have a ride/drive down there and see their work and talk about prices
  8. Airhead replied to Georgiev's topic in General
    Well done Georgi...good work
  9. Greetings Damian For chroming I can recommend Leigh Metal Polishing Services Unit 9 Swinton Hall lnd Est Pendlebury R d Swinton Manchester M27 4AJ Telephone 0161 728 4325
  10. yeah but until its had a decent ride say 10 miles i'll reserve judgement, it needs the long ride and to be up to temp for a while before you can say if you have a problem or not...its been off the road and under maintanance after all. I would expect it to be a bit smoky at first...thats my opinion anyway for what it's worth
  11. take it for a ride smoke is normal when cold
  12. yeah Tony it seals onto a spacer collar and under the collar on the crank is the 'O' ring but i just dont know why jason cant go for a ride and confirm if there is actually a problem or not! it seems its just been built and gone nowhere from whats been said so far.
  13. yeah take it for a good run before coming to any conclusions you did remember the 'O' ring?? seals are open side in closed side out
  14. jay it sounds like the crank seal on the right of the bike, When this seal passes the engine oil gets into the crankase as so gets burned producing the thick smoke, its not a full strip...not even an engine out job but you will need a clutch holding tool to hold the engine still so you can undo the nut on the primary gear altrenatively you will need to remove the cylinder piston and head and place a rod (1/2 inch drive extension bar) through the small end onto wooden blocks so the small end is approx 1/2 stroke aside from this is it possible you forgot to fit the 'O' ring under the spacer behind the primary gear when you worked on the bike last?
  15. the trouble with winter is its effin cold and the salt will wreak havock with your pride and joy!
  16. dohh, can you saw the bolt heads off without too much damage?
  17. Great vid drewpy, looks and sounds fantastic, not as loud as my ss125 used to be tho...
  18. check the carb breather tube is clear and not partially plugged with said clay
  19. Greetings Carlo
  20. yeah she's a beaut Craig
  21. they will do 60 - 70, you may get 80 with an unrestricted one but thats not being very kind, they're not built for speed...the aerodynamics are all wrong,and besides if youre on L's you wont be riding an unrestricted one anyway.... great bikes go for it but beware they are top of the list for thieves!!!!
  22. haha too right .
  23. bike looks great Craig, now show us a proper picture, use photobucket...for instructions see posting pictures in FAQ's...new members forum
  24. Gary have you tried yuniparts or yambits? a good starting point
  25. Airhead replied to Alex's topic in General
    did you re-size it to within the allowed size Craig?
