Airhead
  1. Greetings Shaun
  2. Greetings Pledge lol With that bike? hey classics would be good
  3. Pledge this forum is for intros mate
  4. The length will affect the ride height, if its too far different it will either make it difficult to get your feet down, or the other way round, could cause bottoming out...just guessing though
  5. I dont know the answer but why not compare the length and bolt / pivot sizes for the two models, and if necessary make an adapter sleeve if required, also compare the two bikes to see if they have a similar linkage arrangement
  6. it doesnt have an ignition light Pete, you mean oil light (bulb check)
  7. Greetings Rolfie
  8. HI
    Airhead replied to ScottDT's topic in New Members Welcome Area
    great bikes, never take your eyes off it though!!!
  9. HI
    Greetings scott from Oldham, you got a DTRE then Greetings
  10. lol i was expecting a video, ,,,nice one drewps
  11. Definitely a sought after bike vic, loking forward to seeing some pics
  12. Airhead replied to kearnsy123's topic in The Bar
    yeah some of the XT's are sumo's http://www.google.co.uk/search?hl=en&cp=6&gs_id=j&xhr=t&q=xt660x&rlz=1W1GGLL_enGB401&biw=1024&bih=540&gs_sm=&gs_upl=&bav=on.2,or.r_gc.r_pw.,cf.osb&wrapid=tljp132742867773408&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&ei=ZCMfT_qGNMrz-gbw8vUy
  13. Bet I can find one quicker
  14. does he wash the dishes while you are out enjoying yerself then
  15. Greetings dian, how big is the photo, try one not too many pixels
  16. Airhead replied to Noise's topic in Projects
    kinell come on you two!
  17. Nice intro Dad Lets start with a spark then, has it or hasnt it? have you checked for spark yet? and done the usual with WD40, spraying around the plug cap etc?
  18. mobllette was my intro to bikes too
  19. Mark yeah leave it as it is and get without asap
  20. lol whats the ped? its not far off a bicycle...did you finish it?
  21. Nice intro fella, yeah the XJR 13's are really nice, I like the retro look of em oh and there are some really 'interesting' people in here
  22. how the fuel gets to the engine, lol thats complicated and i'm not about to write an essay...Like I say check the vents are clear and the hole to the choke lift tube is clear, then at least it should run on choke
  23. get the choke working first, it should then start and if it wont run with the choke off after that...well thats another story. also you need to check the bowl vent is clear The choke see the brass tube coming down from the carb body, it goes down into a bored hole in the bowl, at the bottom of that bored hole is a tiny hole into the bowl for fuel to pass through...you need to pass a very small pricker wire through the hole to make sure it's clear. Then the choke shold work and the engine should then run on choke
  24. its a common fault that the choke will not stay out, it doesnt really matter though...you can just hold it out. Your carb does look rough as a bears arse doesnt it!!! but I fear you will have a long wait to find another
  25. Two things, 1: is the choke plunger fitted and working ? 2: dont really like the look of the pilot jet but it's best left alone as yet because if you damage the screwdriver slot you're in deep sh1t you need to investigate the choke first, so is the plunger working correctly? oh and clarify this "It's getting to the float bowl. Just not getting past that point?. " we need it to get further than 'to' the bowl, we want fuel in the bowl
