DT 125 R 1990 powervalve position
Hi sparke so are you using the one with the diamond shaped connection?
DT125 R 1990 engine codes? Powervalve set up
hi sparks so are you using the one with a diamond shaped connection?
The Work has begun...
no mate, mouse over the options and select the one beginning 'IMG'
Hello from Idaho
wow thats a real nice example sacha, has it been restored or is it worse than the pictures portray make out Greetings and
Andrew i see you are using photobucket? copy the IMG tags and paste direct to your forum post and then we can see them on your post you can past multiple pictures to your post and comment on them
Whats Wrong with this picture?
If you chain was (presumably) that worn, you will need to fit new sprockets as well as a new chain
- An even bigger hello from the Isle of Wight!
hello from pennslyvania
greetings cappy, start a thread in projects section
- Big Hello from Sheffield
slipping clutch on xvs 650 dragstar
if you have bike specific oil in there...correct clutch adjustment...correct cable adjustment ... plates and springs within specification you have just ticked all the boxes
Sputter sputter
yeah sounds pretty carb related, probably way too rich gives a kind of 4 stroking feel... a firing of every two revolutions
RS 100 First time project
so all was well and since you had the ignition switch apart you have problems...is this right?
is there a clutch adjusment to be done? and i dont mean cable adjustment perhaps a screw and locknut in the pressure plate? nothing in the manual? not familiar but this is sometimes the case
Sputter sputter
2001! and then one day you found...ten years had got behind you
has it had a new ignition switch? it isnt beyond the realms of possibility you are measuring things like bulb filaments, for example the neutral light.
Not quite 'with' this statement gaz, what do you mean 'beep' multimeters dont beep on voltage settings...only continuity settings!
have you got a wiring diagram gaz, i havent
TTR600 Rear Axle Nut Sourcing - Help!
its not an old bike anyhow,i bet any yamaha agent could have got you one...did you ask 'yambits' by the way?
Whats everyone up to this weekend?
looks good merv, nice weather too
lets eliminate the rectifier, maybe it is connected right but to prove it is or isnt the problem just unplug one of the wires to it with the engine stopped...does this help any? a common place for bad earths is where the loom wraps around the steering head on its way into the headlight...look for chaffing here
Melbourne from Uk
not wasting any time then burnesy, you jumped ship eh Greetings and
New Member Intro
Nice intro Brian, take care and build confidence
Hi Everyone!
Greetings angela
Hello all.
Greetings Nik post up a pic of the old yammie
1977 Yamaha rsx100 - Kickstart lever issue
http://www.google.co.uk/imgres?q=rs100&um=1&hl=en&sa=N&qscrl=1&nord=1&rlz=1T4GGLL_enGB401GB402&biw=1024&bih=540&tbm=isch&tbnid=UoHulR39kF8wtM:&imgrefurl=http://www.bikez.com/motorcycles/yamaha_rs_100_dx_1976.php&docid=v3i1HBlRvXWvQM&imgurl=http://www.bikez.com/pictures/yamaha/1976/10466_0_1_2_rs%252520100%252520dx_Patrick%252520Albrecht%252520(Erich%252520P.).jpg&w=400&h=300&ei=jOVsT5jND8ix0AWosaDBBg&zoom=1&iact=hc&vpx=111&vpy=211&dur=6516&hovh=194&hovw=259&tx=136&ty=137&sig=109572796084677770194&page=2&tbnh=153&tbnw=204&start=10&ndsp=12&ved=1t:429,r:8,s:10That straight one looks a bit like the one here...an RS100?
