Airhead
  1. I went to a UFO sighting in Manchester on friday...Great gig
  2. A new set of rings and a bit of a tart up, shes good to go, went for a spin and someone in a car tried to kill me again!! thats twice now...first time out on the bandit and first time out on the DT
  3. no you cant move the power band to where you'd like it best, just set it up correctly and then 'it is what it is' have fun...great bikes
  4. Airhead replied to flyday58's topic in Classics
    Great news Richard, c'mon lets see her then! maybe today i'll put mine back together :spin2:
  5. half arsed investigation Nik...no offence mate! show me the haynes manual that has RSX100 on the cover, not what you put in a search box! http://www.snazal.com/yamaha-rsrxs100-and-125-singles-owners-workshop-manual-hayne--9781859600559.html?source=webgains&siteid=47684&adnetwork=wg
  6. Greetings Erin some inspiration?
  7. Greetings florin, have you a son called bob?
  8. leave them in, they are to pressurise your fork to your preference, not much pressure i wouldnt think...around 4-8psi at a total guess? Handy for a heavy rider with a full tank and tankbag on etc etc
  9. Airhead replied to clarke's topic in Yamabyss
    you'll be pushing i reckon, all petrol is wiped out around here too
  10. worn emulsion tubes?
  11. Thats bad mate, i'm with RAC but never used them yet so i dunno.....
  12. give yambits a ring for your parts
  13. yeah it probably has the same plastic bushes the DTMX has, thing is you will never get them out of the swing arm without trashing them anyhow so like i said...have a word with jason (cynic)...he did his this way
  14. pictures would help paul
  15. why are you removing the swing arm? is it fitted with black plastic bearing bushes?
  16. life begins at 40 they say alan Enjoy the YBR i'm sure you'll love it Greetings and
  17. sometimes its best to place a stout tube over the head of the bolt (big enough for the bolt to pass through it) and rest this against a solid wall...then all your hammer blow will be effective on the bolt and will not be wasted in flexing the frame. Having said that though...1982....you'll be lucky but it worked for me years ago failing that, hacksaw (ask cynic)
  18. yeah its easy..ask '2wheels' he did his...and in IRL too
  19. most likely the gear shaft seal kearsy, get a new one fitted...not a big job normally
  20. I would be surprised if it hasnt already been done . i'm sure if you use the search function you will find lots of ideas Greetings and
  21. yes Tony they are a great little bike...however this is an RSX...whatever that is?
  22. dont use add image button...just paste direct to your post
  23. ok its late so gotta go, have a look here for setting up the diamond shaped on...post~ #31 with 3MB00 barrel. Not familiar with mixing and matching though but will check out your progress tomorrow. Aside from this I dont see why they should collide although I expect the bigger rebore the more danger of this happening? http://yamahaclub.co...arch_app=forums
