Airhead
  1. see how it is after the rebuild dave and try a few plug, dont know why you mention flooding
  2. mervin will know
  3. nah but it could have been wet with fuel you put through the plug hole. what i meant was...without putting fuel in manually, does the plug get wet with fuel by the way you should buy several spark plugs and try them all, sometimes they can be a bit finicky
  4. the choke..well does the plug get wet with fuel?
  5. yeah you should have stopped when you noticed this, sounds like a bearing seized and the crank spun inside it...is this what you found...a trashed bearing?
  6. Greetings DkD to the forum
  7. Greetings Ragnar to the forum
  8. Greetings Ady to the forum
  9. no pal its not normal, sounds like it needs new crank bearings and seals if there is up/down play at the flywheel
  10. Excellent intro michael, how about a pic of the DTMX?
  11. havent you heard...theres a hose pipe ban !!!
  12. throw up a pic of the bike, the ability to post pictures is always a bonus...see FAQ's in 'New member' forum
  13. you're welcome brendon
  14. always a tricky one this i find david, its late now but tomorrows another day mate
  15. so if it works repeatedly with the jumper and not without it...this means the current flow from the battery... through the fuse and any connectors along the way...through the ignition switch to the flash relay has met some resistance due to dirty or corroded contacts! you need to check all connectors and fuse connection are clean, if you cannot get it to work after doing this then it maybe the contacts in the ignition switch that are dirty...this is an area i am unfamiliar with, i dont know if they can be inspected and cleaned or whether a new ignition switch would be necessary, that one is for you to decide but do the stuff you can do...its late now in uk so i'll check up on you again tomorrow
  16. Greetings david and thanks for the intro fella
  17. sounds good but!! brendon you need to be totally descriptive in your replys...i cannot see what youre doing! jumper...no jumper...dash light ...no dash light...what?
  18. try again, I am encouraged by "it seemed to work" make sure you have a good connection to each end and strong cable...press them down good at each end is the speedo dash light still in cct?
  19. ok so thats a step in the right direction then now try this, use a piece of wire as a jumper, touch one end to battery+ and the other end to Brown on the relay connector, see if the indicators work...dont think you will need to turn the key ON
  20. Greetings tinman
  21. Being as this has become much more than just hello, i'm moving it out of new members
  22. greetings curz, wot no pics without yer shirt on?
  23. some knowlegable members like to see an intro in new members before the questions david...its a forum etiquette thing ya know
  24. if you just want to see if it works just remove an indicator lamp from the speedo and connect the ends across br/wh and Bk at the relay connector...it will be quicker for you
