Airhead
  1. maybe the last owner didnt chain it up John anyway, chains dont stop em!!!!
  2. Greetings will good intro that
  3. dont bind the loom with adhesive tape, use loom tape it's non adhesive and you only fasten it at its extremes with adhesive tape. This gives flexibility. what kind of connectors does the Guzzi have? What about the moulded multi pin connectors, how are you going to do them? dont use pre-insulated bullet connectors, use the froper ones with a proper crimp tool for that kind (cant think of the name of them) PM me your email address if you want a copy of something i scanned from a magazine re building your own loom Mervin will tell you where to get the correctly coloured cables and connectors from
  4. car oil is not recommended at all, it causes clutch slip with bikes...it seems your mate isnt all that clued up about bikes? ant good make of oil will do, 10w 40 is OK
  5. The website has errors then eh... care to post a link? like i said different mikuni VM carbs have different pilot jets! yours will be an M28/1001...order no 004-041 for #25, 004-596 for #27.5 see this link here...DT175 74 to 81 http://www.marshalldistributing.com/files/tech-info/sudcopilotjet.pdf if you can screw in your mixture screw without the motor stumbling the pilot jet fitted is too small....verify this when you get chance Richard
  6. Greetings dohark good luck with finding the R6 see the subscriptions tab at the top of the page...membership is cheap
  7. no shake during shitting eh
  8. looks good to me http://www.google.co...pw.r_qf.,cf.osb
  9. There are 2 adjustments Andy the first is to align the cable pulley marker and the plunger pin when the throttle is closed, use the cable adjuster for this then there is the pump stroke checking and adjustment start the bike idling and watch the front end of the pump, you will see it moving in and out of the pump body, stop the engine when it is out at its fullest extent. Measure using a feeler gauge the gap between the plate and the raised boss of the pump body, do not force the feeler gauge it should be a light sliding fit, the required spec is 0.2 - 0.25mm. if it's incorrect remove the pulley and you will find shims, add or remove shims to achieve the required measurement...usually this works out as adding shims which increases stroke
  10. Airhead replied to kearnsy123's topic in The Bar
    The carbon? you mean carb you'll no doubt have to strip it and clean it all out, it will have no end of gunk in there from a long time in storage, get an aerosol carb cleaner...and a compressed airline would help too
  11. Greetings hayes
  12. Greetings ratty
  13. Greetings Tom
  14. Greetings chuck Andy read the how to in FAQ's...part of the 'New members' forum
  15. i doubt he will be back mate but we'll see
  16. take it out, use a magnifying glass to verify it's blocked. clear it with a soft bristle pulled fron a nail brush or the like and blast some aerosol carb cleaner through it and the place from whence it came
  17. Hmm no mot and you find the clutch slipping...you must have an awfully long driveway michael
  18. almost definitely a blocked pilot jet, especially as it has been standing. The fuel in the bowl evaporates over time and forms a jelly like substance in the bore of the pilot jet. The way to prevent it happening when the bike is laid up is to open the fuel cock every month or so to top up the bowl....for future referance This...assuming it was warm enough to knock off the choke in the first instance
  19. maybe check the alignment marks on the selector drum? it's in the haynes book
  20. it helps them to not shear off in a fall
  21. i posted one today no problem Pete
  22. Has it got new friction plates in michael?... old ones can be a bit hard and glazed! as for springs, fit them anyway, they arent expensive http://www.wemoto.co...ebc_heavy_duty/ I assume you have new oil in there and it was bike specific for wet clutches? if it were me i''d thoroughly clean around the drain plug, drain into something clean and re-use it after fitting the springs / plates...cant see it slipping with a good clutch
  23. jets are available here no problem, i just changed mine from a 20 to a 27.5 in order to get a rich enough idle, perhaps they will send to States?, http://www.allensperformance.co.uk/ http://www.motocarb.co.uk/ mukuni VM carbs come with different type pilot jets, this is the type in our's, i expect yours would be the same it's now 10:34am...cold and wet as usual
