1975 Yamaha RS100 turn signal issues!
then i am guessing you need a new ignition switch unless you can somehow clean the contacts...because the jumpering excercise just bypassed the switch and the associated wiring,you have stated the associated wiring and plugs are clean you could take an ohms reading of it all, take out the fuse and measure between the fuse holder clip (loom side) and the brown connector on the relay, it should be a very low reading 0.5 ohms at a guess
1973 dt250
i think the 20mpg ones have leaking gas tanks !
Yamaha dt125r crank seal
me too mate but i was just answering the question as asked
DT 125 1980 swing arm question
you had me confused saying its a 1980 bike, these did have the square sect swing arms as i thought..its a 1979 model thats why the oil tank is on the left...someone fitted a later arm
Hi
Greetings jester and how are you liking the big draggie?
New!
Greetings spark yep, great bikes
my name is nate, i like motorcycles, beer, and pussy. and im from texas.
Greetings nate, yeah its quite heartwarming to see such affection for small animals from the young generation
yes there are several ways of checking one is to drain the oil remove the engine take off the two engine cases chock up the engine on blocks until the cylinder base gasket face is approimately level (preferably in a tray) fill the crankcase with diesel and watch the two sides checking for weepage how does that sound?
you sure the oil tank is on the left i dont see it? 1980 should be on right shouldnt it?
2002 DT 125R HELP!
thats why i asked you cant just nip these nuts up you have to get a good hold of the rotor and tighten them to the recommended torque...and thats pretty damned tight. if they come loose and the rotor also comes loose you will damege the woodruff key and possibly the recess it sits in and also risk damaging the magneto coils themselves due to heat generated through friction caused by the rotor rubbing the iron cores....hope not! I think you should investigate this area now and not strip that motor fully again unless you are sure about big end play!...how are you judging this 'play' ?
I doubt it isnt the original one Different swing arm different shock absorber different chainguard what side is the oil tank on? what is the vin number?
Problem replacing my TZR50 original exhaust
Rubber? aghh i'm out of my depth here, usually they are heat proof aluminium / fiber jobbies
16 inch xv rear wheel
Get it rebuilt at manchester xtreme with new ss spokes
Is the any benifit to having a cone air filter
not a fan of them myself
yep it would need a gasket fitting between the pipe and the barrel
78 dt175, wont run after hot
how about an intro in new members forum? cheers
Replacing Fork Seals
you need to release the spring tension (take care) Then up end and drain the oil out then remove the allen headed screw at the bottom and pull out the stantion, then the seals can be removed. Take care not to damage / dent the top of the slider when removing the seal. All just a guess, this is how my old bike is......
so then...it is working with the jumper and not without it...is this correct
South Africa - Yamaha FZR 1992 Headlight bulbs???
pretty sure these ship worldwide turs, have a mooch around here http://www.wemoto.com/bikes/Yamaha/FZR_1000_EX_UP_3LE/91-92/
My Introduction :)
welcome in fella, yeah they are a great looking bike, hard to believe they are only a 125. feel free to post up a pic of your pride n joy
newbie
Yeah keep taking the tablets Brian welcome in mate
just new here
Good stuff mate...Off now
just new here
copy the very bottom 'field' Jason, the one beginning ...not the one beginning http
just new here
not bad Jason, whats the plan? get her roadworthy?
- just new here
