Fazer won't start
nahh an oximiser wont overcharge, whatever it means...it doesnt mean 87 amp
Old chain o-ring problem might be affecting new chain?!
He's got a point but if there are tight spots...clearly he's wrong and this really must be addressed immediately by adjusting the tension at the tight spot and ultimately replacing the sprockets. If the chain really does go tight (as in no free play) it will stress the hell out of your gearbox bearing...not good at all. Dont go tinkering yourself with the chain adjustment leave it for the guy you bought it off to do because of the warranty and this being a known problem like...dont give him any excuses that it was you who adjusted it wrong
Never heard of this problem Ross, whats this about sticky spots at certain wheel positions, check the free play of the chain at various positions including when theres a sticky spot.
Belated . . ."Hello All"
Great intro smiley, not boring at all fella
My Maxim Project
is the pipe for the vac line in good condition with nice tight connections at both ends?
My Maxim Project
maybe check your tank is venting properly, is there a vent tube kinked or trapped perhaps, when it happens...is it cured if you stop and open the filler cap?
Hi Guys
Greetings Gen, Quite like the look of the XS650 but never had one...show us then
Fazer won't start
explain this jamjar ? "amps 87/88"
hello all
Greetings rod, a bike for every sunny day eh? you must have a barn for a garage
Newby forgot to introduce
Greetings jamjar and
- How Do
Uh, so close. Now its electrical...maybe.
Its a points ignition system is it? Tell you what my train if thought is. With a points system you may still get a good spark even if the timing is way way out, you could perhaps get a spark that will burn fuel/air in the crancase...perhaps giving a loud sharp 'pop'...maybe (just guessing here) how could it be that the ignition is so far out that this would happen you may ask yourself? Simple...you dont torque up the flywheel tight to within specifications, then you try starting the bike...there is a backfire...this shears the flywheel key and the crank rotates some inside the taper now your timing is way out and all your efforts to start it are in vain!!! Check your ignition timing...if its good then all well and good, if you have torqued up the flywheel to spec...ditto but if you didnt?!!!!
Help me identify this bike
Just what is your problem? you came on here asking for help with id I offered some help, you responded by just how wrong I was someone else comes on and offers the same result and it's thanks matey where did you get that info from WTF as they say
'ola DEA!
Greetings kash they are great little bikes...one day...I can only dream Greetings and
Restoration recommendations
- Restoration recommendations
hey slice i think he may already have the bike, just looking for the labour perhaps ?- What fuel should I be using, also - NOS or K&N air filter?
I would go for an OEM one they're very good. And coat it liberally with the thickest oil you have...then squeeze out the excess (as in dont wring)- Help me identify this bike
ahh so i was right then!!!- fast DT175?
wow! thats amazing, y'know something I would love to see a vid of all this at the track ...whats the chances?- Help me identify this bike
Thats better so continuing with the google thing...does your bike not look like the one here? http://www.mccookracing.com/articles/charlieOxford_OldMotorcycle.htm- Help me identify this bike
thats how I saw it anyway when I suggested you google it...I hadnt but upon your curt reply I did, cant be bothered to look at the other one but http://www.ebay.com/sch/sis.html?_nkw=1976%20Yamaha%20YZ250C%20OIL%20DIPSTICK%20YZ%20250%20control%20dip%20stick%20model%20509%20&_itemId=270895655898- Hello YOC
Greetings Alex and- XT125R chain replacement
is there a split link in the chain?- Help me identify this bike
574 is DT400C mark 509 is YZ250B 1975 Try googling them- FZ6 radiator fan
it wouldnt surprise me if they are different because of the different part number, perhaps the mounting screw positions etc...dont know though - Restoration recommendations
