Airhead
  1. best bet is to strip it down, check the bore, check the piston to bore clearance, check the rings end gap clearance, replace the small end bearing. You will no doubt find the specs in the manual
  2. Its normal, leave it alone...You lie your bike on the ground?
  3. surely it will have some kind of switch fitted in the tank...cant see how this would mean buying a new tank though!
  4. Theres loads on ebay is yours different...whats TID14-78? http://www.ebay.co.uk/itm/YAMAHA-XJ600-CDI-1990-/251142286714?pt=UK_Motorcycle_Parts&hash=item3a793f2d7a
  5. Greetings webtmc and
  6. cant you try the duff bulbs in the known good fuel light socket?
  7. Have you had the relay connection undone to see if that looks in good shape?
  8. You're the one with the haynes manual dude! is the pump protected by a fuse ?
  9. Give Fowlers a ring tomorrow and let us know how you get on http://www.fowlers.co.uk/
  10. cant a yamaha dealer supply them then?
  11. Airhead replied to chelseasmiiiiile's topic in The Bar
    SR125 tappet settings anyone...
  12. Greetings and I guess goodbye looking at your other post
  13. Greetings pablo and I dunno about the damper fella
  14. Airhead replied to shambles1980's topic in The Bar
    yep..check the compression or at least the bore/ piston clearance and ring end gaps
  15. Airhead replied to shambles1980's topic in The Bar
    lol cant even see it in that pic
  16. Airhead replied to shambles1980's topic in The Bar
    is it in the casting...or is that just carbon build up?
  17. Airhead replied to shambles1980's topic in The Bar
    I always though the RXS had quite some respectable power for a tiddler
  18. sorry I mis-read what you said!
  19. thats it then, its not the european version and both the brake plate and axle will be different
  20. He's refering to a TDR as in the title
  21. scrape it off then solvol, use a wood chisel and keep the blade flat to the exhaust and it wont dig in and scratch
  22. all the wheels and forks are the same unless you have an imported leading axle style fork
