Airhead
  1. is it a model code 444? Heres a wiring diagram, not up to much but it's the only one I could find http://www.slimduck....t125_wiring.htm
  2. Airhead replied to smoush's topic in Yamaha Workshop
    if it's fine then check the head gasket some tell-tale signd for the head gasket are water dripping from the frame (well it was on the DTR), and possibly bubbling in the expansion bottle in a bad case
  3. Airhead replied to smoush's topic in Yamaha Workshop
    its usually the head gasket gone but can also be the water pump seal, in that case check your gearbox oil isnt a milky emulsion of oil and water
  4. It's 1978 that was my point I know its not elec start It's virtually the same bike as mine and NEO's
  5. Airhead replied to mojo1162's topic in The Bar
    Dont use your fingers lol, use a wet rag to test the headers are hot
  6. Err if you read the post 6 you will see I am talking about the positive feed to the brake switch...hope I havent confused dewang though he never did PM me an address to send the stuff to! and no I'm not wrong the positive feed to the brake lamp / switch or where ever is never grounded . What IS grounded is the other side of the bulb filament that's permanently grounded...get a meter on yours if ya wanna check as for connecting to the tail light feed and only having warm hands when the lights are on...fair enough if you have a bike with permanant lights on, but the feed to the brake switch is there all the time so thats the usual place to go for
  7. OIl level is always checked with the wheels on the ground and the bike upright as far as I know
  8. Give it a spray of WD40 in there occasionally egghead, It will prevent corrosion from the water ingress
  9. Airhead replied to alfresco's topic in The Bar
    Thats really nice alfresco Will she run without a battery then? But with electric starter??
  10. Airhead replied to *koop*'s topic in Projects
    The steering lock should be the same as the ignition lock if nothing has been changed http://www.pgmyamaha...-23484-01_.html http://www.pgmyamaha...0269-04003.html Check suitability but according to part# these are suitable for DT175MX do I take it you have'nt got parts manuals? PM sent
  11. Airhead replied to Cynic's topic in General
    I really struggle with driving on unlit roads and wherever possible I either wont do it or try to time my journey wisely. Lights are very bright these days and to make it worse the bloody things are almost always adjustable electrically...who do you think gives consideration to others when fiddling with this adjuster.....NOT MANY!!!
  12. Airhead replied to Cynic's topic in General
    yes the yellow tinted ones are for night driving,
  13. Greetings alfresco and your english is just fine
  14. Airhead replied to *koop*'s topic in Projects
    koop for pictures see FAQ's subforum to 'New Members' forum
  15. Greetings and 'Bythesea' 'New members' is really for intros and thanks for using it Can I suggest you start a thread in 'Classics' TIA
  16. PM me your address dewang
  17. yes if the inlet isnt closing because of poor adjustment or a broken spring etc etc...The air/fuel will be pushed back into the airbox on the piston up stroke
  18. no mate, cant be done
  19. Just had a look in the owners manual and I see you are correct, thats the first (modern) bike I've seen without a kill switch! If you havent got this manual It's fee to download here http://www.ymenvom.nl/new/manuals/U3D9E0.PDF
  20. You sure there isnt a big red switch on the RH control?
  21. Greetings Rik, aha a man of taste and a nose for oil burners
  22. Click the 'Forums' tab at the top of the screen, Then in the 'Projects' forum start your own project topic...maybe post a pic early on we like to see them rough from the beginning
  23. Greetings koop, yeah start a project thread up and keep this one an intro
