Airhead
  1. Greetings fazl well done on fixing your bike
  2. well done fazl
  3. Yep, thoroughly enjoyable as always, though the DT was going to let me down bit it seems to have perked up just in time...good to see you guys me n drewpy and a beef sandwich
  4. Greetings Andy and
  5. Greetings tigerwow you still have greenlanes down there...shhh dont let the ramblers know! Greetings and yeah you bought the wrong 250 dohh
  6. well either you have 5 gears or someone downgeared the sprockets then!
  7. I had 80 downhill on a motorway, only once though I just wanted to see it off the clock :0 I'm far too sypathetic a rider normally and would be happy at 65 most of the time, after all those bikes have the frontage of a barn door!!!
  8. Nice one Ken, dont bother about getting the red off, just sand down any rough spots and key the surface then simply spray it heat resist silver How much did it go for BTW? I sold mine many moons ago mate
  9. well it usually means removing the carb and then removing the float bowl from the carb in order to het at the jets, caution though*** the bowl screws are always tight if they have never been off before and you should use a perfect condition philips (not posidrive) screwdriver of exactly the right size or you will round off the screws and wish you'd asked someone to do it for you! The pilot jet usually sits in a recess and requires again (important) the correct size screwdriver...one slip and its buggered...all of it, yeah I know it's all laden with DOOM but I just dont want you to feck it up see
  10. It might be a blocked pilot jet then Paul
  11. is it fuel injection or carburated?
  12. Post an intro then! Grumpy!
  13. Hmm thets a new one, you may be able to revive the plugs on the cooker gas ring and a fine wire brush...as for whats causing it? clean air filter? jet size? you do know how to use the choke... haha?
  14. Greetind Phil DTR's are great bikes when they are running
  15. Greetings blindmelon, it might be a tiddler but it smells reet ha
  16. if the capacitor is wet with fuel/oil then the left crank seal is suspect
  17. check the capacitor isnt shorting from wire to case using a multimeter, the reading should build up to infinite resistance (20M Ohm range)
