Airhead
  1. Airhead replied to Cynic's topic in The Bar
    yeah at least it would give your socks a rest foamy
  2. nice one flyday, in the crank pic.. .wheres the 'O' ring? Why does the taper look so manky? is there some broken material in the keyway?
  3. theres usually a little 'pip' cast into the face of the pulley and when the throttle is closed this should align with the pin thats screwed into the plunger shaft
  4. Airhead posted a topic in The Bar
    Ha sorry to disappoint you I'm not about to slope off just yet Father put his 3 year old daughter to bed, told her a story and listened to her prayers which ended by saying, "God bless Mommy, God bless Daddy, God bless Grandma and good-bye Grandpa." The father asked, 'Why did you say good-bye Grandpa?' The little girl said, "I don't know daddy, it just seemed like the right thing to say." The next day grandpa died. The father thought it was a strange coincidence. A few months later the father put the girl to bed and listened to her prayers which went like this, "God bless Mommy, God Bless Daddy and good-bye Grandma." The next day the grandmother died. "Holy Moses" thought the father, "this kid is in contact with the other side." Several weeks later when the girl was going to bed the dad heard her say, "God bless Mommy and good-bye Daddy." He practically went into shock. He couldn't sleep all night and got up at the crack of dawn to go to his office. He was nervous as a cat all day, had lunch and watched the clock. He figured if he could get by until midnight he would be okay. He felt safe in the office, so instead of going home at the end of the day he stayed there, drinking coffee, looking at his watch and jumping at every sound. Finally, midnight arrived; he breathed a sigh of relief and went home. When he got home his wife said, "I've never seen you work so late. What's the matter?" He said, "I don't want to talk about it, I've just spent the worst day of my life." She said, "You think you had a bad day, you'll never believe what happened to me. This morning my golf pro dropped dead in the middle of my lesson !"
  5. rob. why not investigate price and availability of the correct cam follower arm?
  6. You will see the nut reference# 90170-06128-00 The first part of the number chain '90170' makes it a hex nut, The start of the second part of the number chain the 06 part means Its 6mm diameter http://www.ytcn.nl/archief/Archief/Yamaha%20Parts%20Manuals%20ALL%201950-1996/SR/SR250H.PDF If you want to test that theory, look at other nuts within the listing and you will see it to be correct as far as diameter goes However I dont know how to relate the pitch of the thread to the number While we're on the subject...with an 'ordinary' screw you can get the length and diameter from the part# But to get back 'on topic' it should be 6mm, not 5mm or 7mm!
  7. This might be the water pump seal has gone
  8. leave the nut on but undo it until it's level with the end of the bolt, place a tube on the other side up against a wall and hit the bolt with a proper hammer, a big one
  9. they are usually 5mm, are you sure about that?...doesnt sound right at all to me so surprised...rightly so by the way...you can determine the size from the part number if you check
  10. Yes and yes, but be careful to never spill fuel on the tank because the laquers dont like the stuff!...I assume you're doing it with aerosols
  11. I would think it will be OK, the same applies to the DTRE when fitting a DEP pipe, just block off the pipe
  12. Greetings Torque Wrench
  13. yeah sort the forks out delmsie, cant help with the wrap stuff, whats wrong with it as it stands then the pics are woefully small. see FAQ's for posting decent pics
  14. greetings orestis and nice bikes but that mushroom is something else
  15. Fantastic, sounds as good as a triple eh
  16. Great stuff Sam, at last eh?
  17. +1 with that, I would think there will be something left to get some mole grips on if you drill the head off
  18. Airhead replied to honeybadger's topic in Projects
    honeybadger hasnt been back since sept 3rd nipper
  19. I say the battery is duff, charged or not!
  20. Greetings nipper and welcome in
  21. Greetings ST for a moment there I thought you'd be some old geezer from Scotland, Greetings and
  22. yes it could be the rectifier at fault, first unplug it and visually check the plug/socket for corrosion or melting
