GPR Exhaust on XT125R
looks and sounds fab mate I saw the vid
Rescuing a DT 125 LC
dont know what you mean by that, some of them have a reduced diameter between the bearing surfaces at the ends what is the exact length of the original one?
My GPR exhaust
Nice alex it was a bit of a mother 24s in eh
Gear shift becoming loose and slipping.
is the lever loose on the splined shaft or is there another issue here?
thats nice alex, a great workshop too, top drawer. That silencer looks great is it a G.P.R?
dt125 cdi
of corse you see em on ebay fairly regularly...how come you want one BTW ?
Gilera 4V project
- Yamaha SR250 '83 ignition problems
hi kostas three things 1 what's an astragalus ? 2 has the bike got a kickstart? 3 what about the charge (source) coil specification and measurement?- Gear shift becoming loose and slipping.
youve only had it for four months...take it to be looked at if it's under warranty Oscar- Gear shift becoming loose and slipping.
get it tightened quickly Oscar or you'll bugger the splines!- Gilera 4V project
say hello to Tony from me- A word of advice to XVS 125 owners...
check out the breathers first...the water has to have somewhere to go- A word of advice to XVS 125 owners...
yeah a daily commute of only 4.5 might me the cause try riding straight past work and head out into the countryside- Rescuing a DT 125 LC
maybe a call here? http://shop.bruun-larsen.dk/en/mc-spare-parts-25/yamaha-reservedele-26/frame-parts-32/shaft-pivot-dt125-tdr125-1367.html- carb for 175 dt
I doubt it...why would it be better?- A word of advice to XVS 125 owners...
must have took an awful lot of condensation to do that, check all your breathers are clear and clean- Rescuing a DT 125 LC
I can see this being a great job, tell us about the vinyl wrapping as you progress... I've never seen it done and would like to see how- DT cutting out
no youre not maga testing them, mega tests are for insulation breakdown and charge 500v into the components...no need for that you will use an ordinary multimeter and take resistance readings having switched your dial to the appropriate range for the expected reading...unless your meter is a modern auto ranging jobbie, you'll have plenty of time to pinpoint the fault if the engine needs to cool at this stage we just need to know if the spark disappears when it's quit- Rescuing a DT 125 LC
I thought as much, It makes the whole project so much more difficult due to sellers unwillingness to export items and also so much more expensive! so you really need a good bike to start with that doesnt need many replacement parts...I see yours does look quite good from the photos- DT cutting out
well you have at least 3 coils to consider 1: The HT coil 2: The source coil in the magneto 3: The pulser coil in the magneto Check your manual and see what resistances are quoted for these coils and note them down along with the associated wire colours Chapter 4 Ignition system will give info on how to check these coils- Rescuing a DT 125 LC
how is it getting parts from ebay in Norway? are there parts within Norway or are you having to buy from other countries?- DT cutting out
does it only happen when the engine is hot then...next time whip out the sparkplug and check if it's sparking, If not it may be a coil going open circuit under high temperature, it will be easy to check with a multimeter- which big bike .?
I'm more than happy with my bandit 600- My project featuring possibly the ugliest bike in the world - XJ650 turbo
- crossplane hard starts
Greetings crossplane, i'm same as blackhat It's out of my league too is that i'm only just getting to grips with YDIS - Yamaha SR250 '83 ignition problems
