Airhead
  1. have you checked the pv is still working, do you hear it when you switch the key on?
  2. What a great thing to do, good luck on the journey John and Carmen
  3. nice one rob, wonder what happene to willgree
  4. yeah i'd guess some kind of fault code...is it in the owner manual?
  5. try a spray with wd40 tout, there may be some moisture in there eh?
  6. yeah so it seems, c'mon ben you can google too http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_263941_langId_-1_categoryId_165547
  7. It would be best charged, it would be best to use a bike specific charger too, but if you're desperate a car charger will do for a short while and if it has a low/high setting use low, 15 mins will do If you do end up charging it, check the level is between the max/min lines it may need topping up with distilled water (not tap water)
  8. yeah put it in 3rd gear (or 2nd if you can get away with it) Turn the key on Put choke on Pull the clutch in Sit on the bike and get a friend to push untill you build speed let the clutch out hopefully it will go...be prepared for it to take off with ya so if it fires...be in control of it (pulling the clutch back in usually)
  9. charge the battery before you do anything else, either that or try a bump start
  10. is it elec start, do you hear the click when you hit the start button?
  11. A Gallon is 4.5 litres,...(4500 milli litres) 4500/30 = 150ml so 150ml for 4.5 litres (imperial gallon) if your gallon is US gallon you'll have to find how many litres that equates to and modify this slightly
  12. try googling the tyre size mate
  13. agg dont order it from cpc, google it. They have delivery charges at cpc unless you spend £45 or something...I only posted it for the paint...not the supplier!
  14. is the plug secure Ben? you havent overtightened it and stripped the thread have you? when do you hear the wheezing sound?
  15. have you took out the plug and reconnected to the HT lead, rested the plug on the engine and checked the spark?
  16. try undoing the carb drain screw and turning on the fuel Ken...I'm thinking theres no fuel in the bowl You can check if it's an elec issue easy enough...Just see if the plug is sparking
  17. Greetings Ralph
  18. Greetings Brad...what a great dad
  19. I'd use araldite or an equivalent epoxy adhesive instead of super glue, the sump guard I'd clean up with wet/dry and treat with jenolite then spray with zinc primer first before the silver top coat...cant see it getting all that hot underneath the engine as heat rises? I use this http://cpc.farnell.com/ambersil/6190011512/zinc-primer-400ml/dp/SA02190
  20. just enthusiasts Rick
  21. no john, they all have frame and eng numbers beginning 2K4 even the later ones, its the engine/chassis 'number' that denotes the year
  22. in my experience it usually points to old and dirty contacts in the ignition switch you can prove this to be the case or not by temporarily running a 'live' from the battery to the indicator relay...unplug the brown and fix your 'live' to the terminal on the relay
  23. all it means is it's a DT175MX Rick I havent forgot about the bump stopper, just been to busy to investigate further at the mo
  24. greetings Rob, yeah the little 125 draggie looks like a smart bike...keep it clean especially this time of year
  25. I'd start by looking in the exhaust header but i'm not familiar with your bike, why 50mph...is it a American thing?
